Cannot backup deployment after upgrade to 11.4
1348
12-26-2024 01:38 AM
Yurii_P
Hello! After updating our ArcGIS deployment from 11.3 to 11.4 we no longer can take backups using webgisdr tool. Upgrade was done using cloudformation template provided by Esri. To take backup I run:
opt/arcgis/portal/tools/webgisdr/webgisdr.sh --export --file /opt/arcgis/portal/tools/webgisdr/webgisdr.properties
As a result I receive:
Starting the WebGIS DR utility.
Exception in thread "main" java.lang.NoClassDefFoundError: com/azure/storage/file/datalake/models/DataLakeStorageException
        at com.esri.arcgis.discovery.cache.AccessCredentials$Provider.fromStringIgnoreCase(AccessCredentials.java)
        at com.esri.arcgis.discovery.util.CloudEndpointLocator.b(CloudEndpointLocator.java:218)
        at com.esri.arcgis.discovery.util.CloudEndpointLocator.getProperty(CloudEndpointLocator.java:133)
        at com.esri.arcgis.discovery.util.CloudEndpointLocator.getS3EndPoint(CloudEndpointLocator.java:50)
        at com.esri.arcgis.webgis.storageservice.s3.S3StorageService.a(S3StorageService.java:215)
        at com.esri.arcgis.webgis.storageservice.s3.S3StorageService.<init>(S3StorageService.java:164)
        at com.esri.arcgis.webgis.storageservice.s3.S3StorageProvider.connect(S3StorageProvider.java:19)
        at com.esri.arcgis.webgis.storageservice.StorageManager.getConnection(StorageManager.java:63)
        at com.esri.arcgis.webgis.service.impl.WebGISDRFrontController.service(WebGISDRFrontController.java:132)
        at com.esri.arcgis.webgis.service.impl.WebGISDRManager.b(WebGISDRManager.java:193)
        at com.esri.arcgis.webgis.service.impl.WebGISDRManager.exportWebGIS(WebGISDRManager.java:177)
        at com.esri.arcgis.webgis.client.WebGISDR.main(WebGISDR.java:138)
Caused by: java.lang.ClassNotFoundException: com.azure.storage.file.datalake.models.DataLakeStorageException
        at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(Unknown Source)
        at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(Unknown Source)
        at java.base/java.lang.ClassLoader.loadClass(Unknown Source)
        ... 12 more
I guess I may be missing some properties from my webgisdr.properties file because I replaced original webgisdr.properties by the same file from 11.3. I tried to recreate it manually using properties from https://enterprise.arcgis.com/en/portal/latest/administer/linux/populate-webgisdr-tool-properties-fi... but no success, I still receive same error.
Tags (3)
Yurii_P
This problem exists even on fresh install
SeanF
by Esri Contributor
Workaround
Copy the azure-storage-file-datalake.jar file from the Portal for ArcGIS framework\lib directory into the tools\webgisdr\lib directory.
Issue fixed on 11.5
https://support.esri.com/en-us/bug/the-web-gis-disaster-recovery-webgisdr-tool-fails-to-ru-bug-00017...
Sean F.
Esri Support Services
