Can't connect ArcGis Pro to Portal.
5886
01-17-2017 09:09 AM
JordanBaumgardner
I'm trying to publish a 3d Scene from ArcGis pro. When I attempt to add my portal it fails.
I installed ArcGis Server 10.4 and added a data source.
I installed WebAdaptor.
I installed ArcGis Portal 10.4 and configured WebAdaptor
https://xx.xxx.xx.xxx/arcgis/home/  works.
https://xx.xxx.xx.xxx/:7443/arcgis/home/  works
from ArcGis Pro I add the portal
it says: "Unable to add the portal. Please make sure that the specified portal is up, running and the URL is correct."
as does /home
If I add the :7443 it works kinda - it registers but if I log in it simply does nothing.
--- If I give it the wrong creds - it says they are the wrong creds.
--- If I give it the correct creds - the pop-up login window closes and the portal entry in the list box says I need to log in.
Thanks in advance.
JordanBaumgardner
I enabled Anonymous auth in IIS Manager for the web adaptor and disabled windows auth. This allowed me to connect with and with out the :7443 port url. It must have been re-routing back through the web adaptor.  I think I have mixed modes. My ArcGis Server is ArcGIS Server Built-in as is Portal but IIS was all Windows Auth. I'll align them all.
JordanBaumgardner
