I am using Portal for ArcGIS 10.2.1 and ArcGIS Server 10.2.1. Everything works perfect when they are federated and ArcGIS Server as a hosting server. I can publish map sevices from Portal for ARcGIS to ArcGIS Server. and I access ArcGIS Map services through portal token.
But there is a requirement to use the ArcGIS Map services without any token so I went to the admin/security/config and i have changed it to GIS_Server which works fine from this side , but i tried to publish a shape file as a feature service from Portal for ArcGIS and i got failed to decrypt token . publishing failed.
Can anybody help resolving that ?
Kareem
