Calculate Area on the Fly?
1266
05-05-2020 10:16 AM
RyanBohan
Working on a web app that allows users to easy view, create & edit simple polygons.  Is there a way to automatically calculate area on the fly and save it to the attribute table?  I am using the smart edit widget and I can easily find the zip code for a given polygon and save it to the table, just want to do the same with the area.
The annoying thing is a I calculate the pop-up using arcade: Area(Geometry($feature), 'square-meters') But I can’t figure out how to save that value to the table.
XanderBakker
Esri Esteemed Contributor
Hi Ryan Bohan ,
Since you posted this in Portal for ArcGIS, may I assume that you have ArcGIS Enteprise? If so, you could use a calculation attribute rule that will be triggered on the insert or update events of a feature: Introduction to attribute rules—Geodatabases | Documentation
