Auto-populate shapefiles with predefined symbology/style
1425
12-12-2013 01:28 AM
JessieCallender
I regularly create phase 1 studies and field/tree etc have to be represented in the same way throughout.
Is there a way of creating a style format and then when ever I create a new shapefile I can just import it in the symbology.
So for instance the style format will be a green cross for a  broadleaved tree, then when i create a shapefile of broadleeved trees I can just use the same style.
How do I go about creating this and then being able to call on it?
808707
Check out .lyr files. They will do what you want.
Edit: Sorry I should say you'll need a field populated with the attributes you want to capture.
Edit: Actually are you based in the UK? If so you can download a Phase 1 Habitat Survey STYLE file half way down this page
http://jncc.defra.gov.uk/page-4258
michaelcollins1
You can create your own symbology, or you can just save the default symbols into your own default style.
Pick a symbol, then select "Save As" etc. (see attachment).
You can create symbology by choosing "Edit Symbol" instead, then save it.
These will then appears on your symbol selector
JessieCallender
Thanks, this has been really helpful.
