ArcGIS web Adaptor supports NAT?
1493
6
12-20-2017 01:12 PM
SergioAlarcon_Ortega
we´re installing Portal in Higth Available , so we have hardware balancer (HB) to ServerWeb where we want to install WebAdaptor.
For security, this HA implement Network Address Translation (NAT)  too.
When we configure web adaptor, write https://<HBalias.domain.com>/<webadaptorname>/webadaptor.
it doesn’t work
Howerver, if we write https://<ServerWeb1.domain.com>/<webadaptorname>/webadaptor, then it does
BillFox
MVP Notable Contributor
Hi Sergio,
Did you add the shared NAT ip in DNS and IIS?
Hi Bill,
both ip were added in dns, but i think webadaptor checks if ip where is installed is the same ip where is register, but for NAT is not.
thank you.
BillFox
Is the NAT-ed ip added as a second ip to the NIC on the server where web adaptor is installed?
Thank you.  Bill, I ask our Network Administrator.
Bill , NAT-ed is not added. Is it necessary?
BillFox
yes, and use a wildcard SSL cert for your domain
also, this was a pain to try and update,so we dropped back to non-HA portal and ArcGIS Server.
