ArcGIS Server 10.4.1 patch installation and subsequent Data Store matters
844
01-01-2019 05:57 PM
StephenRetallack2
I recently applied all ArcGIS Server 10.4.1 and Portal for ArcGIS patches and noticed when I was using the ArcGIS Data Store command describedatastore, two things changed:
  1. Is backup folder shared.............false (was true)
  2. Data store status...................RecoveryFailed
Why?
The data store still appears to be backing up okay to the back up network location.
Maybe not related but, I have not applied the Data Store integrity patch for 10.4.1 (ArcGIS Data Store Data Integrity Patch ) since the Windows "Instructions for relational data store machines"  step 5 states:
"Run the configuredatastore utility and specify '--operation repair'. There is no need to run this on the standby relational data store."
There is no such repair operation at 10.4.1. so I didn't take the risk of upgrading. This is the command options at 10.4.1:
E:\ArcGIS\DataStore\tools>configuredatastore.bat
Usage: "configuredatastore serverURL serverAdminUser serverAdminPassword directory [--stores [relati
onal][,][tileCache][,][spatiotemporal]] [--nosql-only true|false]"
and help:
ArcGIS Data Store command utility reference—Portal for ArcGIS (10.4.1) | ArcGIS Enterprise
nor 10.6.1:
ArcGIS Data Store command utility reference—Portal for ArcGIS (10.6) | ArcGIS Enterprise
plus I noticed in my 10.6.1 test environment the configuredatastore.bat file is empty:
Is there something corrupt with my 10.6.1 install?
Thanks
Tags (1)
StephenRetallack2
I was able to sort out the configuredatastore.bat issue on the 10.6.1 install, but still there is no '--operation repair' and may not be applicable at this version.
Also, I corrected the backup location share issue and Data Store status by stopping the the ArcGIS Data Store Windows Service and changing the associated values in the arcgis-data-store-config.json file. Then restarted the service.
