ArcGIS Enterprise 11.0: Configuring web adaptor for portal fails and ends up with “Portal for ArcGIS configuration requires fully qualified domain name in the Portal URL” error,
I couldn’t figure out why the Configuring web adaptor for portal fails and ends up with “Portal for ArcGIS configuration requires fully qualified domain name in the Portal URL” error.
I’m working at the moment in test environment then I assume that the “self-signed certificate” should be sufficient to proceed with the configuration the same way the web adaptor can be configured for ArcGIS Server (it works with self-signed certificate).
