Arcade to filter polygon features based on another feature table in Web Map
745
11-22-2024 01:07 AM
KendallJames73
I have a polygon layer that I want to filter in Web Map based on the common records (like a join) in table (point layer) so that the polygon layer only displays the match features.  There is a common field in both.  The FeaureSetByName function is not available when I try this in arcade.  I also don't have a Custom Arcade or Expression Builder option in the Filter tool.
Any ideas?
Portal for ArcGIS 11.1.
Creator User Type.
JakeSkinner
Esri Esteemed Contributor
Hi @KendallJames73
Hosted feature layer views could be an option, but if it's not feasible to have hosted feature services, you could create a spatial view if the data is stored in an Enterprise Geodatabase.
JakeSkinner
Hi @KendallJames73
KendallJames73
Thanks Jake.  I was thinking about a spatial view so guess I'll go down that route.  Cheers.
