Arcade expression to populate hosted table field
516
04-01-2025 02:17 PM
TKSHEP
I am looking for help with an arcade expression to autopopulate a field on an hosted table based on a field in a hosted feature layer.  Example: hosted table & hosted feature - fields code_number & status
If code_number on both hosted table & hosted feature match then return the status from the hosted feature into the corresponding status field into the hosted table.
I hope this makes sense, any help would be greatly appreciated.
Thank you!
Mowgli_GIS
Hi, I've never done this with a hosted table, but I used a similar script based on matching fields between hosted layers to extract and then insert data from one layer to the other.  My understanding of Arcade is basic, but I adjusted the script to fit what I think you're trying to do, but again this is if they were both hosted layers, not sure how it would need to be adjusted for a hosted table:
var Hfeature = FeatureSetByName($map, "Hosted Feature", ['code_number','status'])
for (var f in Hfeature) {
  if (f.code_number == $feature.code_number) {
return (f.status)
  } else {
    return 'No Status'
Hopefully this helps or at least gets you part of the way!
Mowgli_GIS
return (f.status)
  } else {
    return 'No Status'
