Append data to Hosted feature layer
1185
01-14-2025 10:55 AM
Labels (2)
BryanLynn1
I am trying to use a Python script to update data in a hosted feature layer from a csv file. The new data (csv file) uploads to the Enterprise Portal 10.9.1 as expected. I can truncate the data in the hosted feature layer as well. However, when I try to append the new data to the existing hosted feature layer, I get the following error:
streetNamesData.append(item_id=newStreetsItem.id, upload_format="csv", source_info=para1, source_table_name=tableName, update_geometry=False) Exception: Error downloading item from Portal. (Error Code: 500)
Python script is written in ArcGIS Pro 3.0.6 Python environment. Below is my code.
import arcpy
import arcgis
from arcgis.gis import GIS
import os
import datetime as dt
# Variables
portalUrl = "thePortalUrl"
username = "myUserName"                                         # Enterprise Username
password = "myPassword"                                         # Enterprise Password
hostedStreetNamesItemId = "c1fb90623f47457ea0ee26a1256f2228"    # Feature Service Item ID to update
# Local Feature Class name
runOnProd = True
sdeStreetNames = "KGIS.TRANS_STREETNAME"
# Environment Variables
arcpy.env.overwriteOutput = True
#   Get the current database SDE connection for test or prod
#   based on the runOnProd flag
def getSDEConnection():
    if runOnProd:
        return "prodConnection.sde"
    else:
        return "testConnection.sde"
if __name__ == "__main__":
    # Create GIS object
    print("Connecting to Enterprise")
    gis = GIS(portalUrl, username, password)
    # Create a filename with a timestamp for uniqueness
    now_ts = str(int(dt.datetime.now().timestamp()))
    tableName = "StreetNameExport_{}".format(now_ts)
    filename = "{}\{}.csv".format(arcpy.env.scratchFolder, tableName)
    csvTitle = "TEMP - {}".format(tableName)
    # Get the street names table in SDE
    sdeStreetNamesTable = "{}\\{}".format(getSDEConnection(), sdeStreetNames)
    # Set the field mappings to only export the STREET_NAME field
    fms = arcpy.FieldMappings()
    fm_streetName = arcpy.FieldMap()
    fm_streetName.addInputField(sdeStreetNamesTable, "STREET_NAME")
    outFm_streetName = fm_streetName.outputField
    outFm_streetName.name = "STREET_NAME"
    fm_streetName.outputField = outFm_streetName
    fms.addFieldMap(fm_streetName)
    # Export the data to a csv file
    arcpy.conversion.ExportTable(sdeStreetNamesTable, filename, "STREETNAME_STATUS = 1", "NOT_USE_ALIAS", fms)
    newStreetsProperties={'title':csvTitle, 'description':'Temp CSV file for updating active street names' , 'tags':'temp'}
    newStreetsItem = gis.content.add(item_properties=newStreetsProperties, data=filename)
    # Get featureService/hostedTable layer to update
    streetNamesLayer = gis.content.get(hostedStreetNamesItemId)
    streetNamesData = streetNamesLayer.tables[0]
    print("Truncating Existing Table")
    print("Disabling Sync")
    flc = arcgis.features.FeatureLayerCollection(streetNamesLayer.url, gis)
    properties = flc.properties.capabilities
    updateDict = {"capabilities": "Query", "syncEnabled": False}
    flc.manager.update_definition(updateDict)
    print("Truncating Feature Service")
    streetNamesData.manager.truncate()
    print("Enabling Sync")
    updateDict = {"capabilities": properties, "syncEnabled": True}
    print("Appending features")
    para1 = gis.content.analyze(item=newStreetsItem, file_type="csv")
DavidPike
MVP Notable Contributor
BryanLynn1
Thank you!!!  I looked for something like that but didn't see it. Way better way to look at code.
