Hi, I had the same problem.I just grouped all layers into one and it works correctly.Michaela Zemkova
I'd never noticed this issue prior to loading SP3 last week but just exported 36 pages to PDF and just about every page had annotation and in some case point elements outside data frame. I just used CutePDF and it wasn't a problem.Mark
I have also encountered this problem in a new version 10 database.Here is a very goofy solution:In Layout view, create a graphic rectangle that goes out the edge of the page. (can use guides for this)Create another rectangle the same size as the Data Frame, align to the data frameSelect rectangle 2, then rectangle 1, and choose Drawing --> Graphic Opperations --> Subtract. You will now have a square doughnut graphic that frames your Data Frame.Send the new graphic to the backSend the Data Frame to the backSet the graphic to have the same border you want your Data Frame to have.Now when you export, the square doughnut graphic will mask anything that hangs out of the Data Frame.
Go to data frame properies-->Data Frame tab---> Clip options---->clip to current data driven page extent
