AGS 10.3 Data store - SDE connections
3281
02-19-2015 02:05 PM
BobWheeler
Anyone else having issues using ArcGIS manager 10.3 to add your SDE connections to the datastore?  We have been unsuccessful in manager - can add folders without an issue.  We have had to use Catalog to add our SDE connections.  Not really a bit issues as we have the work around, but has been futile in all 5 installs of AGS.
JakeSkinner
Esri Esteemed Contributor
Hi Bob,
What is the error you are receiving when you try to add the SDE geodatabase as a data store?
BobWheeler
That is part of the issue -  no error - just sits there forever attempting to add.  I have let it set for well over 30 minutes.  Takes a quick 10 seconds in AC.  I haven't tried to run Fiddler to see what it is doing in the background as of yet.
