Adding a live feed JSON API to ArcGIS Portal Web Map
1055
10-17-2023 01:49 AM
MANESK
The requirement is to add a live feed of JSON API to ArcGIS Portal Web Map. Is there any documentation or steps to execute it. Request your suggestions
JakeSkinner
Esri Esteemed Contributor
Hi @MANESK,
You can do this using ArcGIS GeoEvent Server.  GeoEvent allows you to poll APIs and write the data (i.e. JSON) to a feature service.
MANESK
Thanks Jake. Will look into that.
