Activate Popup for several layer in webmap portal
640
04-01-2019 11:13 PM
tommykurniawan1
Hi All,
Is someone know how to Activate Popup for several layer in webmap portal, in single or simple seting.. not one by one per layer. Thanks
PanagiotisPapadopoulos
Maybe ArcGIS Assistant tool can help you
https://ago-assistant.esri.com/
By default a layer on a webmap without popup enabled has this setting, disablePopUp: true
If you change this setting to false then this layer has the Pop up enabled with the default Pop Up settings
