Accessing ArcGIS services in Portal vs. ArcGIS Online
5898
03-18-2015 05:25 PM
BobbiLay
I have several perfectly nice arcgis services published and readily visible in rest.  Can I add them to my content in ArcGIS Online?  Yes!  No problem!  Can I add them the same way in Portal?  NO!
ERROR
Service " does not exist or is inaccessible.
No it isn't!! It's the same address!!!
C'mon Portal... please?
Any ideas?
VenusScott
These types of issues are why I use the profile picture I do . . .
glennhazelton
check and see that you are working thru the webadapter and don't have the port number in the url for portal when  you are adding content.
SeemaJoshi1
Strange behavior but I too experienced similar issue.
I managed to handle it using following workaround, copied URL of some already added Service, pasted that URL and replaced Service Name....It worked perfectly fine for me ...I still needs to explore reason behind it.
BobbiLay
Turns out it was a certificate error.  Gah!  So many moving parts!  Thanks all.
brettangel
Do you mind elaborating on what type of certificate error was causing the problem?  I am having similar problems, but cannot seem to figure it out.
