10.9.1 portal/sharing/proxy
1328
12-13-2024 04:53 AM
nippo
When I load "https://<fqdn>/portal/home/organization.html", there are XHR requests to "https://<fqdn>/portal/sharing/proxy?https://local.portal/sharing/rest/search" with 500 HTTP Status code as responses.
My private Portal URL is "https://local.portal:7443/arcgis", not "https://local.portal".
I wonder where this parameter is set?
Thanks!
Tags (3)
TimoT
Hi nippo,
The privateportalURL is mainly used for communication between your federated Servers and Portal, so you wouldn't be seeing privateportalURL requests unless you were looking at traffic between your Server and Portal.
  1. If you navigate to https://<fqdn>/portal/sharing/rest/info, what do you get for the Owning System and Token Service URLs?
  2. Have you set a WebContextURL on your Portal?
  3. Do you have any Web Adaptors and/or load balancers / reverse proxies? If you do have web adaptors, what is your web adaptor URL (check portaladmin > system > webadaptors)
nippo
Thanks for your answer! I changed the way I path through "The username you entered is not a member of this organization." : https://community.esri.com/t5/arcgis-enterprise-portal-questions/linux-upgrade-10-7-1-to-10-9-1-quot...
I continue my staging process but I did not have anymore 500 XHR on https://<fqdn>/portal/home/organization.html
