1 datastore 2 ArcGIS servers
1271
06-23-2019 05:17 AM
OmerBen-Asher
I have a need to connect one datastore for 2 ArcGIS servers as the secondary datastore for both of the servers, does the datastore support this configuration?
Thank you.
AnthonyRyanEQL
Omer,
Can you please provide more information (eg. Are the 2 servers in different server sites)?
OmerBen-Asher
Yes, they are in different server site. They are 2 different and full ArcGIS enterprise 10.7 each with its one primary datastore.
I wonder if I can connect the two servers to the same datastore (to use as secondary)
Thank you.
JonathanQuinn
Esri Notable Contributor
I assume you're referring to the ArcGIS Data Store, and no, it doesn't support being registered to two distinct sites. You'll need to set up two separate servers, install the ArcGIS Data Store on each, and configure them as separate standby Data Stores for each primary.
