Create a registered cloud store for Azure with a SAS token?
1652
07-26-2023 03:18 PM
FredSpataro
Hi All,
In ArcPro, I can connect to my Azure blob storage container using the SAS token by setting the token value in the Provider Options: AZURE_STORAGE_SAS_TOKEN property.
However the 'Provider Options' values are not accessible in the UI dialog for either ArcGIS Server manager nor ArcGIS Portal.   Does this mean we CAN'T use a SAS token to register the Azure blob storage container in enterprise?  Maybe using the REST endpoint? So far no luck figuring out a syntax there.
When we try thru the ArcPRO UI, we get critical failure with the "Report to Esri" dialog box 😞
Thanks
LeoDCG
Yes you can use an SAS token in Pro, but you can't add it as a datastore in portal from what I can tell.. make sure you have the region, service endpoint and arc deep crawl set to NO
