Hi there,
I would like my chart to filter, select and zoom to selected features in the map. At the moment it selects and filters but does not zoom to the features.
This is how my chart actions are set up
And this is the map
Any pointers would be greatly appreciated thanks 🙂
But we are able to select/flash the feature on Select Data Records Trigger/Action.
Then why we are not able to zoom to feature.
Can any ESRI people respond on this. Or please let us know if it can be implemented in future releases.
Because it is very common functionality that any user can look for zoom to feature on bar chart item click.
Ashok
I dug for a while and found that this should be a known limitation at this moment. For W-Chart & W-Map interactions, there are only Flash and Filter supported. It appears that the options of "Zoom" and "Pan" in the Chart widget were not removed from the UI so it is documented here: ExB Chart widget > interaction options note
For this function itself -
From my understanding, unlike the Query widget, which directly utilizes the added data source, Chart creates an output data source (i.e. Chart statistics) right when data gets rendered. Once that happens, it lost all geospatial reference, thus, there is no way to get the extent for zoom or pan which depends on geometry, when you select anything from the Chart widget.
We will look into that and see if there will be any enhancement possibilities.
I too would like to have the ability to select features in a chart and have the map pan and zoom. After talking with ESRI support, I have learned that this is a known limitation and that an enhancement case has been opened: ENH-000151058 Chart: support geometry-related message actions like zoom/pan to. Experience Builder = work in progress.
I am hoping that @Jianxia may be able to provide the status on the ability to select a feature in an Experience Builder bar chart widget for example and then see the map pan and zoom on the selected feature.
Does ESRI have plans to address this known limitation dating back to 2022? A user should be able to select a bar on a bar chart and have the map pan and zoom to the location on the map. I will submit an enhancement request to check on the status of this important (2,360 views at the time of this post) functionality.
