Apologies if this is already possible, if it is can you please share how. I would like to see the popups I configure in ArcGIS Pro to be retained when published as a service to a Portal or ArcGIS server and accessed from the rest endpoint. If my map services are being accessed and brought into Portal/ArcGIS online/ArcGIS Pro using the add data from path, I would like end users to see the popups the way I configured them not just a list of attributes.
Thanks
Dan
