How To Get the .soe File From VS 2015 Projects
1849
07-10-2017 10:47 AM
BehrouzHosseini
Using this Geometric Network Utility SOE Rest project and VS 2015 I am able to build the project and eventually I am getting following dlls at
..\Documents\Visual Studio 2015\Projects\SOE\ByPhaseGeometricNetworkUtility\obj\Debug
enter image description here
and in
..\Documents\Visual Studio 2015\Projects\SOE\ByPhaseGeometricNetworkUtility\bin\Debug
can you please let me know how to get/create .soe file now?
nicogis
MVP Alum
Are you in this situation ?
Problems with .NET SDK SOE templates at 10.2 in Visual Studio 2012 prevent the .soe file from being generated.
The cause of this bug and the issue you are having are the same.
The workaround would be :
Edit the project file *.csproj:
Near the bottom of the XML you will see an Import element. For both Project and Condition, update the path from Server.targets to Server.11.targets.
Fernando-Matos
Hi!
How do you solve this?
