Enterprise SDK and the removal of ArcMap based runtime post 10.9.1
2342
04-15-2021 08:32 AM
DanielRouleau
With regards to the DevSummit 2021 discussion of the removal of the ArcMap-based runtime from ArcGIS Enterprise, there were slides discussing that MapServers using SOE and SOI would be affected, and I wanted some clarification on if that meant all SOE and SOI, as there are capabilities of the Enterprise SDK that work only with services published from ArcGIS Pro, such as the Utility Network Tracing SOE example here https://github.com/Esri/arcgis-enterprise-sdk-resources/tree/master/Samples/dot%20net/SOE/UNTracingR....
Will SOE written using the Enterprise SDK like the sample above be affected by the 2022 releases without the ArcMap-based runtime, or are those SOE intended to work largely as-is with releases past 2021?
nicogis
SOE and SOI developed with Enterprise sdk always are ok after last ArcGIS Enterprise 10.9.x, part of the ArcGIS 2021 releases. You cannot use SOE and SOI developed with ArcObjects .NET/Java SDK in version released after last ArcGIS Enterprise 10.9.x, part of the ArcGIS 2021 releases  because the ArcGIS 2022 releases of ArcGIS Enterprise will only contain the ArcGIS Pro-based runtime
Removal of ArcMap-based runtime from ArcGIS Enterprise (esri.com)
nicogis
DanielRouleau
Thanks, I also was sent this handy blog post that goes over the answer in detail as well, that those SOE written with Enterprise SDK will continue to be supported moving forward. Migrating ArcObjects SOEs and SOIs to ArcGIS Enterprise SDK
nicogis
