Report ArcGIS Enterprise/ArcGIS Online Item Dependencies
47237
91
04-15-2020 12:29 PM
This tool will create a report on the dependencies for a service or a web map.  This can be helpful to see what web maps/applications will be affected by making changes, or deleting, a particular item.  When creating a report for feature services, the tool will report which web maps and web applications are consuming the service.  When creating a report for a web map, the tool will report which web applications are consuming the web map.
A CSV file is created from this tool.  Below is an example report created for 2 feature services, Cities and NYPD_Crimes:
The Cities service is found in 2 web maps, Cities Web Map and Airports Web Map.  The Airports Web Map also has an application created from it called Airports Web App.
The NYPD_Crimes service is only found in 1 web map, NYPD Crimes Web Map.
See the video below for a demonstration:
Note:  this tool was created using the ArcGIS API for Python, and can only be executed within ArcGIS Pro, not ArcMap.
Update 8/2/21:  tool now works with ArcGIS Online.  The ArcGIS Online version can take a significant amount of time.  It's dependent on the number of users you have in your ArcGIS Online organization, as the tool iterates through each Creator user type and checks their web maps/web appbuilder applications.
Update 10/19/22:  tool will report Experience Builder and Dashboard applications.  A 'sleep' parameter has been added to the ArcGIS Online version to help avoid too many requests to ArcGIS Online, resulting in the tool to fail.
Update 9/5/23:  whether you are creating a report from ArcGIS Online, or Portal for ArcGIS, a single tool can be used.  A sleep parameter is no longer required if running against ArcGIS Online.
Update 10/6/23:  can now select multiple users
Update 7/17/24:  support for Image Services
Update 7/29/24:  support for Story Map applications, and for stand-alone services in Experience Builder applications and Dashboards
Update 7/11/25: supported with ArcGIS API for Python 2.4.1 (Item Dependency.zip), ArcGIS API for Python 2.4 and earlier (i.e. ArcGIS Pro 3.4 and earlier) download the Item Dependency - Python API 2.4. and Earlier.zip
Update 8/26/25: GP services are supported with ArcGIS API for Python 2.4.1 (Item Dependency.zip).  It will report WAB and Experience App Builder applications referencing the GP service URL
Comments
AbiDhakal
@JakeSkinner  - Thank you, Jake. It worked right and the tool is great!
jakek
@JakeSkinner Jake this a great tool.  What we noticed yesterday is that it may not be recognizing single sign on (SSO) for AGOL.  I'm an admin on AGOL in my organization where SSO was implemented a while back.  When I enter the AGOL URL, it looks good then a red X shows on that parameter when I put in my credentials.  Any ideas?  Let me know if you need more info or screenshots, etc.
Thank you for spending the time to develop it and keep it updated.  Much appreciated.
JakeSkinner
Esri Esteemed Contributor
@jakek are you using a SAML IDP (i.e. Entra, Okta)?  Unfortunately, SAML is not currently supported.  You will need to use a built-in account, or an Active Directory account.  If using an Active Directory account, windows authentication cannot be enabled at the web adaptor level.
jakek
@JakeSkinner Ok I'll see about taking another route to get there.  Thank you again.
AryamanBhattacharya_BeansAI
The tool is exactly what GIS admins need! It is super useful and works like a charm @JakeSkinner !
I had one suggestion/feedback though. Do you think it will be possible to include a 'Select All' option for both the 'Source User' and 'User content' parameters ?
Thanks in advance!
JakeSkinner
@AryamanBhattacharya_BeansAI this already exists.  Click the arrow next to the Source User/User Content parameter:
Then click the top checkbox to select all:
MatthewMalone
This tool is SO HELPFUL when undergoing planning to remove/replace any key feature layer.  I appreciate you putting this toolbox out here for all to use!
Cheers!
-Matt
P.S. I'm running the tool with Pro 3.4 on AGO services and it runs 3-4 times as fast as the version I first used back in 2021!
GMcG_Geo
Thanks for the tool ..its really helpful, however I'm having problems running the tool in the latest version of Pro (3.5.2). I had it running previously but I now get an error message when it tries to populate the User Content field  (but error message appears next to the ArcGIS Online/Portal URL field):
Any help/info appreciated...
JakeSkinner
@GMcG_Geo I updated the tool to be supported with ArcGIS API for Python 2.4.1.  Re-download the latest version and you should be good now.
GMcG_Geo
Thanks @JakeSkinner that works great now!
emilymcbroomdenton
Hi! We are trying to use this tool and looking for the parameters for the toolbox if you can provide a  screen shot.
When I pull the python script into a toolbox and try to open it I receive this error message,
"Reading tool has failed. Error HRESULT E_FAIL has been returned from a call to a COM component."
Thanks for your help!
JakeSkinner
@emilymcbroomdenton take a look at a few posts up and you'll see a screen shot.  Also, the video will demonstrate the entire workflow.
Are you attempting this for Enterprise or ArcGIS Online?
Sibe
@Jake I'm running into the exact same issue as @emilymcbroomdenton . I'm attempting to use this for Enterprise.
JakeSkinner
@Sibe what version of ArcGIS Enterprise and ArcGIS Pro are you running?
Sibe
@Jake ArcGIS Enterprise 11.1 and ArcGIS Pro 3.3.0
JakeSkinner
@Sibe I just uploaded an earlier version (Item Dependency - Python API 2.4 and Earlier.zip) that should work with your version of Pro.
Sibe
@JakeSkinnerThanks! I tried that, but I’m still getting an error. Any idea what else I could check?
JakeSkinner
@Sibe do you get this after you enter your username/password?  If so, are you using a SAML account?  This is currently not supported, only built-in and Active Directory accounts.
Sibe
@JakeSkinnerThanks, it’s working now.
RClavero
Hello @JakeSkinner, first, many thanks for making this tool available (and for keeping it up to date); it's very useful.
While using it, in 'User content', I don't see the ArcGIS Enterprise published geoprocessing services appear. Is this expected? I'm also looking for an overview of which geoprocessing services are being used in the different ArcGIS Enterprise portal web apps (GP services added as a widget).
JakeSkinner
@RClavero I've updated the code to include GP services.  You can download the Item_Dependency.zip and you should be good to go.
RClavero
Hi @JakeSkinner, thanks for the quick update & reponse. I realized I can't test it yet since I'm still at ArcGIS Enterprise 11.3 and ArcGIS Pro 3.3.
JakeSkinner
@RClavero download the Item_Dependency.zip and use that with your existing script tool by right-clicking on the script tool > Properties > Execution tab:
The differences between the Item_Dependency.zip and the Item Dependency - Python API 2.4. and Earlier.zip is only the Validation within the toolbox.
RClavero
@JakeSkinner, I tested your suggestion but under 'User Content' I still don't see the GP services. I have used an AD user with admin role, and I'm also the item owner of those GP services in the Portal. I used ArcGIS Pro 3.3 and the ArcGIS Enterprise is the 11.3; in the ArcGIS Pro Package Manager I see arcgis 2.3.0.
Reading this above, "GP services are supported with ArcGIS API for Python 2.4.1", I probably need to be using a newer version of the ArcGIS Python API for the script to work as expected (?). I will test once we have upgraded to 3.5/11.5 (not yet planned).
Context: In the Esri Developer docs I see: The ArcGIS API for Python 2.4.0 release is supported with ArcGIS Pro 3.4 and later cloned environments, and ArcGIS Enterprise 11.4 and later.
JakeSkinner
@RClavero that was my mistake, there are changes to the Validation.  You can easily add this with the following steps:
1.  Right-click on the script > Properties > Validation
2.  Update the following lines:
elif 'Map Service' in str(item.typeKeywords) or 'Feature Service' in str(item.typeKeywords) or 'Image Service' in str(item.typeKeywords) and 'Hosted Service' not in str(item.typeKeywords):
with:
elif 'Map Service' in str(item.typeKeywords) or 'Feature Service' in str(item.typeKeywords) or 'Image Service' in str(item.typeKeywords) or 'Geoprocessing Service' in str(item.typeKeywords) and 'Hosted Service' not in str(item.typeKeywords):
May be difficult to see above, but you're just adding the following:
MarkWILSON_LLS
well done @JakeSkinner  and thankyou.
Ive got MFA enabled on my account. Is there anyway the script can refer to my AGOL login in pro or feed the AGOL MFA into the script?
Ive built my own dependency report via ArcGIS Python API but havent got the dependancy linkages working correctly.
thanks
mw
Jonathan_Marin
Hello,
I'm using arcgis pro 3.5.4 with enterprise 11.3, and I'm unable to use the tool at all. As soon as I finish typing my password for the admin user I get the "arcgis has stopped working" error message. Do you know if my combination of versions is not compatible? I have used this tool in the past without issue earlier this year.
Also, if I use our AGOL credentials the tool works, but not our enterprise portal.
Thanks in advanced!
JakeSkinner
@Jonathan_Marin the API changed at 3.5, so make sure you have the latest toolset (Item Dependency.zip).
Also, what type of user are trying to connect with?  For example, is it a Portal built-in account (i.e. portaladmin), or a SAML account (i.e. jskinner@esri.com)?
Jonathan_Marin
Hi @JakeSkinner I downloaded the latest version of the tool and I am using a built-in account. The tool basically fails the moment that I finish adding the admin credentials. If I type in a non-admin account's credentials, I get the "incorrect user or password" error as it attempts to connect, but once I type in the correct siteadmin credentials it fails right after the blue dots appear on top of the GP window that shows it validating the connection.
JakeSkinner
@Jonathan_Marin it looks like the entire ArcGIS Pro application is crashing.  This seems like an issue with your installation of Pro.  Do you have another server that is running Pro to test with?
Jonathan_Marin
Hello @JakeSkinner ,
I just did a fresh installation on a different machine and did the same steps as my workstation and get the same issues. Do you have any ideas of what the issue could be?
Thank you
JakeSkinner
@Jonathan_Marin does ArcGIS Pro crash if you try connecting to AGOL rather than ArcGIS Enterprise?
Jonathan_Marin
Hi @JakeSkinner, no issues connecting to AGOL only when connecting to portal.
Charlie_Kaufman
Hi @JakeSkinner, I just downloaded your Item_Dependncy.zip tool.  This looks to be exactly what I need.  I'm running ArcPro 3.5.2.  When I load all my admin credentials, I get the dropdown options for the Source Users but not for the User Content option.  I tried to type in a name to run a test but thing seem to have hung up.  Any advice would be appreciated.
Thanks
JakeSkinner
@Charlie_Kaufman does the kaufmanc_sac user own services?
Charlie_Kaufman
@JakeSkinner , that might be part of the issue.  No services just hosted feature layers.  But I switched the content type to Web Maps and still no drop down option appears.
Also, I am all of a sudden getting the infamous "error 032659" red x that many others are reporting.  But it is appearing now randomly even after I fill in all the fields.
So I am obviously in need of some assistance.  🙂
JakeSkinner
@Charlie_Kaufman the hosted feature layers are AGOL hosted feature services, which should show under the User Content.  Can you click on one of those and verify user kaufmanc_sac is the owner?
Charlie_Kaufman
@JakeSkinner oh yeah.  I'm testing this on the items that I own in my folders, so I own everything.  Is there anything else I can try on my end?
JakeSkinner
@Charlie_Kaufman is there another Administrator account you can try?
Charlie_Kaufman
@JakeSkinner, so one of our other Admins was able to see his User Content.  However, when trying to output the CSV file this error popped up. Exception: Unable to find ItemInfo for item 'a560d9bf48e74231be4ea7fb9396f025'.  I was also able to use my credentials to view our other Admin's account and saw his User Content, but got the exact same error when trying to output the CSV.
There is no item 'a560d9bf48e74231be4ea7fb9396f025'in our Organization.
I still can't see my own User Content when using my own credentials.
MarkWILSON_LLS
Gday all.
@JakeSkinner , I hope you dont mind, I've taken and adapted your script to run for non-Admins.
I'm sure it's not the prettiest or most efficient script but hope this helps any other non-admins that want to track and audit their own dependency relationships.
If it can be improved further, please let me know.
thanks
mw
##User Dependency Script##
#Source info adapted from "Report ArcGIS Enterprise/ArcGIS Online Item Dependencies" by Jake Skinner
#https://community.esri.com/t5/arcgis-enterprise-documents/report-arcgis-enterprise-arcgis-online-item/tac-p/1665944
#this script will run for current AGOL login via ArcPro
#Toggle CONTENT_TYPE to run the report for Services or Web Maps under User Configuration section.
import arcpy
import json
import re
import os
from arcgis.gis import GIS
from datetime import datetime
from time import perf_counter
# USER CONFIGURATION
CONTENT_TYPE = "Services"   # "Services" or "Web Maps"
OUTPUT_DIR = r"C:\Temp\AGOL_Audit"
arcpy.env.overwriteOutput = True
# TIME SETUP
script_start = datetime.now()
script_start_str = script_start.strftime("%Y-%m-%d %H:%M:%S")
print(f"Script started at {script_start_str}")
date_stamp = script_start.strftime("%Y%m%d_%H%M%S")
content_tag = CONTENT_TYPE.lower().replace(" ", "_")
output_filename = f"agol_{content_tag}_audit_{date_stamp}.csv"
os.makedirs(OUTPUT_DIR, exist_ok=True)
csv_output = os.path.join(OUTPUT_DIR, output_filename)
# FUNCTIONS
def get_folder_title(folder):
    """API-safe folder title extraction"""
    if hasattr(folder, "title"):
        return folder.title
    elif isinstance(folder, dict):
        return folder.get("title")
    return None
def checkWebApps(appDict):
    global apps
    for app in appDict.values():
        appJSON = app_json_cache.get(app.id, "")
        if CONTENT_TYPE == 'Services':
            if webMap.id in appJSON or itemURL in appJSON or item.id in appJSON:
                output_file.write(
                    f'{itemTitle},{item.id},{webMap.title},{webMap.id},{app.title},{app.id}\n'
                apps = 1
        elif CONTENT_TYPE == 'Web Maps':
            if webMap.id in appJSON:
                output_file.write(
                    f'{itemTitle},{item.id},{app.title},{app.id}\n'
                apps = 1
# MAIN
gis = GIS("pro")
user = gis.users.me
arcpy.AddMessage(f"AGOL self-audit started for user: {user.username}")
output_file = open(csv_output, 'w', encoding='utf-8')
output_file.write("# AGOL Dependency Audit\n")
output_file.write(f"# User: {user.username}\n")
output_file.write(f"# Content Type: {CONTENT_TYPE}\n")
output_file.write(f"# Start Time: {script_start_str}\n")
output_file.write("# --------------------------------------------------\n")
    output_file.write(
        'SERVICE NAME,SERVICE ID,WEB MAP NAME,WEB MAP ID,APP NAME,APP ID\n'
else:
    output_file.write(
        'WEB MAP NAME,WEB MAP ID,APP NAME,APP ID\n'
# COLLECT CONTENT
webMapDict = {}
webAppDict = {}
expAppDict = {}
dashboardDict = {}
audit_items = []
def collect_items(items):
    for i in items:
        if i.type == 'Web Map':
            webMapDict[i.title] = i
        elif i.type == 'Web Mapping Application':
            webAppDict[i.title] = i
        elif i.type == 'Web Experience':
            expAppDict[i.title] = i
        elif i.type in ('Dashboard', 'StoryMap'):
            dashboardDict[i.title] = i
        if CONTENT_TYPE == 'Services' and i.type in (
            'Feature Service',
            'Map Service',
            'Image Service'
            audit_items.append(i)
        elif CONTENT_TYPE == 'Web Maps' and i.type == 'Web Map':
# Root items
collect_items(user.items(max_items=10000))
# ✅ Definitive folder-safe iteration
for folder in user.folders:
    folder_title = get_folder_title(folder)
    if folder_title:
        collect_items(user.items(folder=folder_title, max_items=10000))
# BUILD APP JSON CACHE
cache_start = perf_counter()
app_json_cache = {}
all_apps = (
    list(webAppDict.values()) +
    list(expAppDict.values()) +
    list(dashboardDict.values())
for app in all_apps:
    try:
        app_json_cache[app.id] = json.dumps(app.get_data(try_json=True))
    except Exception:
        app_json_cache[app.id] = ""
cache_time = round(perf_counter() - cache_start, 2)
# DEPENDENCY AUDIT WITH PROGRESS
audit_start = perf_counter()
total_items = len(audit_items)
processed = 0
report_every = max(1, total_items // 10)
for item in audit_items:
    processed += 1
    hasDependencies = False
    apps = 0
    itemTitle = re.sub(',', '', item.title)
        itemURL = item.url
        for webMap in webMapDict.values():
            webMapJSON = json.dumps(webMap.get_data(try_json=True))
            if item.id in webMapJSON or itemURL in webMapJSON:
                hasDependencies = True
                checkWebApps(webAppDict)
                checkWebApps(expAppDict)
                checkWebApps(dashboardDict)
        if not hasDependencies:
            output_file.write(f'{itemTitle},{item.id}\n')
        webMap = item
        if apps == 0:
    if processed % report_every == 0 or processed == total_items:
        arcpy.AddMessage(f"Progress: {processed}/{total_items}")
audit_time = round(perf_counter() - audit_start, 2)
output_file.write(f"# App JSON Cache Time (s): {cache_time}\n")
output_file.write(f"# Dependency Scan Time (s): {audit_time}\n")
output_file.close()
arcpy.AddMessage(f"Audit complete: {csv_output}")
Version history
Last update:
‎08-27-2025 05:59 AM
Updated by:
Contributors
