We are currently unable to connect our ArcGIS Enterprise portal (10.9.1) to Power Automate triggers. We keep receiving the following error message. I have tried reauthenticating multiple times using different apps, but we are still facing the same error.
Failed to retrieve dynamic outputs. As a result, this operation's outputs might not be visible in subsequent actions. Error details: The dynamic operation request to API 'arcgisenterprise' operation 'GetWebhookPayloadSchema' failed with status code 'BadRequest'. This may indicate invalid input parameters. Error response: { "message": "Fetching data from #######.com.au/portal failed. This is usually caused by an invalid authentication token that has expired. Please reauthenticate to continue. Error message: Error: unable to verify the first certificate fetch failedIf the error persists, please check ArcGIS Enterprise Client ID and App Secret provided", "success": false }
