Table layers not working with 'Fetch updates, changes, or deletions from feature layer' action
3321
8
02-07-2023 10:18 AM
Kuyler_JonesCivil
I'm running in to trouble with Table layer types. When using the Fetch updates, changes, or deletions from feature layer action, whenever I select a feature layer that is a table, I get the following error when trying to save.
Flow save failed with code 'DynamicOperationRequestClientFailure' and message 'The dynamic operation request to API 'arcgis' operation 'GetFeatureLayerResponseSchemaForWebhook' failed with status code 'BadRequest'. This may indicate invalid input parameters. Error response: { "message": "Cannot read property 'toLowerCase' of undefined", "error": {} }'.
Is there a special process for table layers? Or are they simply not supported?
Update Edit: I also get the same error when using a Table in the Get data from feature layer action, but only when the Output format is set to JSON. I am only able to get Table data as CSV. This makes me think that there is an issue treating Tables as JSON.
AnthonyLatini
@Kuyler_JonesCivil - Hello there! My name is Anthony and I am a product engineer on the ArcGIS for Power Automate connector. I was looking over this issue and I would like to help out if I can!
We have just pushed a number of fixes earlier this afternoon that should resolve this issue. Please let me know what happens when you attempt to recreate or run this flow again. Below is an example using a table in an action and having it succeed.
You should be able to save the flow without any issues now.
SeanKMcGinnis
@Kuyler_JonesCivil  - sorry you are running into this. Could you please submit this a support ticket on this and we will be able to get the correct resources looking into the issue.
-sean
Sean McGinnis - Principal Product Manager, ArcGIS for Microsoft
Kuyler_JonesCivil
Thanks Sean. I have submitted a support ticket. It is Case number #03268187
AnthonyLatini
Kuyler_JonesCivil
@AnthonyLatini thank you for the swift response. It seems that the issue has been fixed.
AJD
Hello @AnthonyLatini @SeanKMcGinnis ,
I am running into the same issue. I am using the default flow provided in the Power Automate (Keep track when record updated in feature layer) and I am getting the same error when adding my layer.
Beard_Greg
@AnthonyLatini, I'm having the same issue. Any chance this is back?
ZacharyHart
Honored Contributor
ZacharyHart
Honored Contributor
@AnthonyLatini @SeanKMcGinnis  Have you guys seen this thread??
