Hi All,
My requirement is need to verify the urls given by some external users in json file. i need to load the json and read urls from it , need to verify whether service urls exists or not in portal using arcgis python api.
@Anonymous User ,
You can use the following script to get the existing portal services in a list. Then compare it with the url list from json.
from arcgis import GIS gis = GIS("portal url", username, password, verify_cert=False) # for feature layers fcs = gis.content.search("*", item_type="Feature Layer", max_items=100) portal_service_urls = [fc.url for fc in fcs] ..... json_urls = [...] # Compare the 2 lists set(portal_service_urls) & set(json_urls)
I hope that helps.
moved to ArcGIS API for Python Questions - Esri Community to give you a better chance of getting an answer
If you only need to check the existence of the endpoint URLs in the json, you could do something like this with a simple GET request. A HEAD request is also an option, but results can be unreliable.
import requests def url_exists(url): req = requests.get(url) if req.status_code == 200: print('Endpoint exists') return True ... for url in your_json['endpoints']: url_exists(url) ...
Signed in members can post, follow updates, and more. New here? Register a free account.
