The clock in Set realistic env. Settings static?
1363
12-02-2019 11:47 PM
KennethLindhardt1
Hi using the exact same script, as on https://developers.arcgis.com/javascript/latest/sample-code/scene-environment/index.html the clock is static at 12:00, and you can’t turn it.
I get some errors in the console, directly to the clock.js, but I don’t know where to go from here.
Anyone got this working?
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8" />
<meta
name="viewport"
content="initial-scale=1,maximum-scale=1,user-scalable=no"
<title>Set realistic environment settings in a SceneView - 4.13</title>
<link
rel="stylesheet"
href="https://js.arcgis.com/4.13/esri/themes/light/main.css"
<script src="https://js.arcgis.com/4.13/"></script>
<script>
require([
"esri/Map",
"esri/views/SceneView",
"esri/layers/SceneLayer",
"esri/widgets/Home",
"Clock.js"
], function(Map, SceneView, SceneLayer, Home, Clock) {
var map = new Map({
basemap: "satellite",
ground: "world-elevation",
layers: [
new SceneLayer({
portalItem: {
var view = new SceneView({
map: map,
container: "viewDiv",
// position in Brest, France
camera: {
// autocasts as esri/Camera
position: {
// autocasts as esri/geometry/Point
x: -500180.363,
y: 6170505.212,
z: 27.623,
spatialReference: {
// autocasts as esri/geometry/SpatialReference
wkid: 102100
heading: 204.85,
tilt: 104.94,
fov: 80
environment: {
atmosphere: {
// creates a realistic view of the atmosphere
quality: "high"
lighting: {
date: new Date(),
directShadowsEnabled: true,
// don't update the view time when user pans.
// The clock widget drives the time
cameraTrackingEnabled: false
ui: {
components: ["attribution"]
// configure the UI
var homeWidget = new Home({
view: view
view.ui.add(homeWidget, "top-right");
view.ui.add("timeInfo", "top-left");
var clock = new Clock({
el: "clock",
skin:
"https://developers.arcgis.com/javascript/latest/sample-code/scene-environment/live/clock.svg",
time: view.environment.lighting.date.getTime()
view.ui.add("clock", "bottom-right");
// update the time of the view when the clock time changes
var timeField = document.getElementById("timeField");
var updateTimefield = function() {
timeField.innerHTML = view.environment.lighting.date.toLocaleString();
updateTimefield();
clock.on("time-change", function(time) {
view.environment.lighting.date = time;
updateTimefield();
</script>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
#timeInfo {
color: white;
#timeField {
font-size: 20px;
#timeLocation {
font-size: 30px;
#clock {
width: 220px;
height: 220px;
.esri-ui-corner .esri-component {
box-shadow: inherit;
</style>
</head>
<body>
<div id="viewDiv" class="esri-widget">
<div id="timeInfo">
<span id="timeLocation">Brest, France</span> <br />
<span id="timeField"></span>
</div>
<div id="clock"></div>
</div>
</body>
</html>
KennethLindhardt1
I’ve copied my own script, with the clock included, into the sandbox, and that works. It sill not works outside the sandbox. Am I missing a node.js package or something? What is required to run the clock??
KennethLindhardt1
I’ve got it to work. Copying the SVG creating the clock, and placed it locally inside node.js then it worked
