I get some errors in the console, directly to the clock.js, but I donât know where to go from here.
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8" />
<meta
name="viewport"
content="initial-scale=1,maximum-scale=1,user-scalable=no"
<title>Set realistic environment settings in a SceneView - 4.13</title>
<link
rel="stylesheet"
<script>
require([
"esri/Map",
"esri/views/SceneView",
"esri/layers/SceneLayer",
"esri/widgets/Home",
"Clock.js"
], function(Map, SceneView, SceneLayer, Home, Clock) {
var map = new Map({
basemap: "satellite",
ground: "world-elevation",
layers: [
new SceneLayer({
portalItem: {
var view = new SceneView({
map: map,
container: "viewDiv",
// position in Brest, France
camera: {
// autocasts as esri/Camera
position: {
// autocasts as esri/geometry/Point
x: -500180.363,
y: 6170505.212,
z: 27.623,
spatialReference: {
// autocasts as esri/geometry/SpatialReference
wkid: 102100
heading: 204.85,
tilt: 104.94,
fov: 80
environment: {
atmosphere: {
// creates a realistic view of the atmosphere
quality: "high"
lighting: {
date: new Date(),
directShadowsEnabled: true,
// don't update the view time when user pans.
// The clock widget drives the time
cameraTrackingEnabled: false
ui: {
components: ["attribution"]
// configure the UI
var homeWidget = new Home({
view: view
view.ui.add(homeWidget, "top-right");
view.ui.add("timeInfo", "top-left");
var clock = new Clock({
el: "clock",
skin:
time: view.environment.lighting.date.getTime()
view.ui.add("clock", "bottom-right");
// update the time of the view when the clock time changes
var timeField = document.getElementById("timeField");
var updateTimefield = function() {
timeField.innerHTML = view.environment.lighting.date.toLocaleString();
updateTimefield();
clock.on("time-change", function(time) {
view.environment.lighting.date = time;
updateTimefield();
</script>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
#timeInfo {
color: white;
#timeField {
font-size: 20px;
#timeLocation {
font-size: 30px;
#clock {
width: 220px;
height: 220px;
.esri-ui-corner .esri-component {
box-shadow: inherit;
</style>
</head>
<body>
<div id="viewDiv" class="esri-widget">
<div id="timeInfo">
<span id="timeLocation">Brest, France</span> <br />
<span id="timeField"></span>
</div>
<div id="clock"></div>
</div>
</body>
</html>
