It would be great if administrators setting up a Workforce project could define custom fields for the assignment layer.
Some businesses, such as ours, track jobs/assignments that have extra complexity and require extra information to be tracked which extend beyond the basic schema of the current assignment layer.
Certainly, there are many businesses that have fully fledged external job management software packages and the expected workflow is to tie the two together using Workforce's 'external work order' number, and then use scripts or manually administration to push and pull data between the two. But there will be a large number of businesses like ours that could and would like to manage their work assignments fully in Workforce and could only do this if there is the flexibility to add extra fields.
