For the new primary locator roles it would be really helpful to get the input search field values in the response. This way it can be checked to matched candidate.
We are trying to use the new PointAddress and Streets Roles but getting invalid matches which did not occur in the SubAddress locator in 10.x. Due to these mismatches it would helpful to see what the input search address was so it can be compared to the result.
In this example below, we are entering and a single line input: 4791 PELL DR STE 1, SACRAMENTO, 95837
However the match comes back without the STE which is not correct and should not have the 100% match score.
The 10.x SubAddress locator returned no matches which is a better result but realistically there should be a candidate match with a lower score than 100.
If the search input was in the result we would easily be able to compare the search string with the match string to weed thru these mismatches.
