Currently you can manually define a list of fields to restrict data values in ArcGIS Online.
You can even "Generate List" from the data in a field at a given time.
The problem is, you do not always have all data categories represented in a feature dataset when you want to set up a list (thus, Generate List only generates a subset of the attributes that you want in the list).
I would like to see a "List Import" option in ArcGIS Online Field List Configuration.
