<SPAN class="comment token"># ---- by column</SPAN>
dirr<SPAN class="punctuation token">(</SPAN>art<SPAN class="punctuation token">,</SPAN> colwise<SPAN class="operator token">=</SPAN><SPAN class="token boolean">True</SPAN><SPAN class="punctuation token">,</SPAN> cols<SPAN class="operator token">=</SPAN><SPAN class="number token">4</SPAN><SPAN class="punctuation token">,</SPAN> sub<SPAN class="operator token">=</SPAN><SPAN class="string token">'arr'</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN>
<SPAN class="operator token">|</SPAN> dir<SPAN class="punctuation token">(</SPAN>arraytools<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN>
<SPAN class="operator token">|</SPAN> <SPAN class="operator token"><</SPAN>module <SPAN class="string token">'arraytools'</SPAN> <SPAN class="keyword token">from</SPAN> <SPAN class="string token">'C:\\Git_Dan\\arraytools\\__init__.py'</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="punctuation token">(</SPAN><SPAN class="number token">001</SPAN><SPAN class="punctuation token">)</SPAN> _arr_common arr_pnts array2raster array_struct
<SPAN class="punctuation token">(</SPAN><SPAN class="number token">002</SPAN><SPAN class="punctuation token">)</SPAN> arr2xyz arr_polygon_fc array_fc arrays_cols
<SPAN class="punctuation token">(</SPAN><SPAN class="number token">003</SPAN><SPAN class="punctuation token">)</SPAN> arr_json arr_polyline_fc
<SPAN class="comment token"># ---- by row</SPAN>
dirr<SPAN class="punctuation token">(</SPAN>art<SPAN class="punctuation token">,</SPAN> colwise<SPAN class="operator token">=</SPAN><SPAN class="token boolean">False</SPAN><SPAN class="punctuation token">,</SPAN> cols<SPAN class="operator token">=</SPAN><SPAN class="number token">4</SPAN><SPAN class="punctuation token">,</SPAN> sub<SPAN class="operator token">=</SPAN><SPAN class="string token">'arr'</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">(</SPAN><SPAN class="number token">001</SPAN><SPAN class="punctuation token">)</SPAN> _arr_common arr2xyz arr_json arr_pnts
<SPAN class="punctuation token">(</SPAN><SPAN class="number token">002</SPAN><SPAN class="punctuation token">)</SPAN> arr_polygon_fc arr_polyline_fc array2raster
<SPAN class="punctuation token">(</SPAN><SPAN class="number token">003</SPAN><SPAN class="punctuation token">)</SPAN> array_fc array_struct arrays_cols
<SPAN class="comment token"># ---- standard method</SPAN>
dir<SPAN class="punctuation token">(</SPAN>art<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">[</SPAN><SPAN class="string token">'__all__'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'__args'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'__art_modules__'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'__art_version__'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'__builtins__'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'__cached__'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'__doc__'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'__file__'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'__loader__'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'__name__'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'__package__'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'__path__'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'__spec__'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_arr_common'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_center'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_centroid'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_common'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_convert'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'_cursor_array'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_demo_frmt'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_demo_ma'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_demo_rec'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_densify_2D'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_describe'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'_even_odd'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_extent'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_flat_'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_func'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_geo_array'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_get_shapes'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_help'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'_id_geom_array'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_max'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_min'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_ndarray'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_new_view_'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_pad_'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_pad_even_odd'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'_pad_nan'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_pad_zero'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_props'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_reshape_'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_split_array'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_two_arrays'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'_unpack'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_view_'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_xy'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_xyID'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_xy_idx'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'a_filter'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'a_io'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'all_folders'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'analysis'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'angle_2pnts'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'angle_np'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'angle_seq'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'angles_poly'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'apt'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'arc_np'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'areas'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'arr2xyz'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'arr_json'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'arr_pnts'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'arr_polygon_fc'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'arr_polyline_fc'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'array2raster'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'array_fc'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'array_struct'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'arrays_cols'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'azim_np'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'block'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'block_arr'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'centers'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'centroids'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'change_arr'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'change_fld'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'circle'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> snip<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN> |
