https://community.esri.com/people/EPolle_TensingInternational/blog/2020/06/14/tutorial-arcgis-api-for-javascript-4x-table-of-contents
listMode: show or hide
OK - This is a nice one to share, I think. The question is:
I have two layers in my file that are scale dependent. How can I force the layerlist widget to only show that layer when the user is zoomed in to the point that the layer is visible and able to be turned on and off?
We will show how to do this. As you can see in the code of the web map below, for one of the feature layers in the view (the municipalities) the minScale (minimum scale) is set to 500000. This means that if the view is zoomed out beyond the scale of 1:500,000 that layer will no longer be visible in the view.
By default, layers that are present but not visible in the view are grayed out in the LayerList. But now we do NOT want to show invisible layers at all in this list and only add them at scales where they are visible.
The trick to accomplish this, is:
- 'watch' the scale of the map with a watch handler
- set the listMode of the layer to hide or show accordingly.
And this is the code needed to do this trick:
<SPAN class="comment token">// watch handler: the callback fires each time the scale of the view changes</SPAN>
<SPAN class="keyword token">var</SPAN> handle <SPAN class="operator token">=</SPAN> view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">watch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'scale'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>newScale<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Scale: "</SPAN><SPAN class="punctuation token">,</SPAN> newScale<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>newScale <SPAN class="operator token">></SPAN> <SPAN class="number token">500000</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
dutchMunicipalitiesLayer<SPAN class="punctuation token">.</SPAN>listMode <SPAN class="operator token">=</SPAN> <SPAN class="string token">'hide'</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">else</SPAN> <SPAN class="punctuation token">{</SPAN>
dutchMunicipalitiesLayer<SPAN class="punctuation token">.</SPAN>listMode <SPAN class="operator token">=</SPAN> <SPAN class="string token">'show'</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>You can see the full solution in action via this link:
ArcGIS JavaScript Tutorial - Scale dependent layers visibility in LayerList
And the full code (html, css and javascript) is listed below:
<SPAN class="doctype token"><!DOCTYPE html></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>html</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>head</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>meta</SPAN> <SPAN class="attr-name token">charset</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>utf-8<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>meta</SPAN> <SPAN class="attr-name token">name</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>viewport<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">content</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>initial-scale<SPAN class="punctuation token">=</SPAN>1, maximum-scale<SPAN class="punctuation token">=</SPAN>1, user-scalable<SPAN class="punctuation token">=</SPAN>no<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>title</SPAN><SPAN class="punctuation token">></SPAN></SPAN>ArcGIS JavaScript Tutorial - Scale dependent layers visibility in LayerList<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>title</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="language-css style token"><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>style</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="selector token">html, body, #viewDiv</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="property token">padding</SPAN><SPAN class="punctuation token">:</SPAN> 0<SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">margin</SPAN><SPAN class="punctuation token">:</SPAN> 0<SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">height</SPAN><SPAN class="punctuation token">:</SPAN> 100%<SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">width</SPAN><SPAN class="punctuation token">:</SPAN> 100%<SPAN class="punctuation token">;</SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>style</SPAN><SPAN class="punctuation token">></SPAN></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>link</SPAN> <SPAN class="attr-name token">rel</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>stylesheet<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">href</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>https://js.arcgis.com/4.12/esri/css/main.css<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="language-javascript script token"><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>script</SPAN> <SPAN class="attr-name token">src</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>https://js.arcgis.com/4.12/<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>script</SPAN><SPAN class="punctuation token">></SPAN></SPAN></SPAN>
<SPAN class="language-javascript script token"><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>script</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>
<SPAN class="string token">"esri/Map"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/geometry/Point"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/views/MapView"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/layers/FeatureLayer"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/widgets/LayerList"</SPAN>
<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>Map<SPAN class="punctuation token">,</SPAN> Point<SPAN class="punctuation token">,</SPAN> MapView<SPAN class="punctuation token">,</SPAN> FeatureLayer<SPAN class="punctuation token">,</SPAN> LayerList<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
basemap<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
portalItem<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
id<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"7aea6fa913a94176a1074edb40690318"</SPAN> <SPAN class="comment token">// Topo RD</SPAN>
<SPAN class="keyword token">var</SPAN> popupTemplate <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">// autocasts as new PopupTemplate()</SPAN>
title<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"The municipality of {Gemeentenaam}"</SPAN><SPAN class="punctuation token">,</SPAN>
content<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Municipal Code: {GM_Code}"</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> renderer <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>
type<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"simple"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="comment token">// autocasts as new SimpleRenderer()</SPAN>
symbol<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
type<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"simple-fill"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="comment token">// autocasts as new SimpleFillSymbol()</SPAN>
style<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"none"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="comment token">// The polygon has no fill</SPAN>
outline<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">// autocasts as new SimpleLineSymbol()</SPAN>
width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1.5</SPAN><SPAN class="punctuation token">,</SPAN>
color<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"#F5B041"</SPAN> <SPAN class="comment token">// Hex Color Code</SPAN>
<SPAN class="keyword token">var</SPAN> dutchMunicipalitiesLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FeatureLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
url<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"https://services.arcgis.com/nSZVuSZjHpEZZbRo/arcgis/rest/services/Bestuurlijke_Grenzen_Gemeenten_2019/FeatureServer/0"</SPAN><SPAN class="punctuation token">,</SPAN>
title<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Municipalities (2019)"</SPAN><SPAN class="punctuation token">,</SPAN>
popupTemplate<SPAN class="punctuation token">:</SPAN> popupTemplate<SPAN class="punctuation token">,</SPAN>
renderer<SPAN class="punctuation token">:</SPAN> renderer<SPAN class="punctuation token">,</SPAN>
minScale<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">500000</SPAN>
popupTemplate<SPAN class="punctuation token">.</SPAN>title <SPAN class="operator token">=</SPAN> <SPAN class="string token">"The province of {Provincienaam}"</SPAN><SPAN class="punctuation token">;</SPAN>
popupTemplate<SPAN class="punctuation token">.</SPAN>content <SPAN class="operator token">=</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">;</SPAN>
renderer<SPAN class="punctuation token">.</SPAN>symbol<SPAN class="punctuation token">.</SPAN>outline<SPAN class="punctuation token">.</SPAN>width <SPAN class="operator token">=</SPAN> <SPAN class="number token">2.5</SPAN><SPAN class="punctuation token">;</SPAN>
renderer<SPAN class="punctuation token">.</SPAN>symbol<SPAN class="punctuation token">.</SPAN>outline<SPAN class="punctuation token">.</SPAN>color <SPAN class="operator token">=</SPAN> <SPAN class="string token">"#8B4513"</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> dutchProvincesLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FeatureLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
url<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"https://services.arcgis.com/nSZVuSZjHpEZZbRo/ArcGIS/rest/services/Bestuurlijke_Grenzen_Provincies_2019/FeatureServer/0"</SPAN><SPAN class="punctuation token">,</SPAN>
title<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Provinces (2019)"</SPAN><SPAN class="punctuation token">,</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addMany</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>dutchMunicipalitiesLayer<SPAN class="punctuation token">,</SPAN> dutchProvincesLayer<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> view <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">MapView</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
spatialReference<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">28992</SPAN><SPAN class="punctuation token">,</SPAN>
container<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"viewDiv"</SPAN><SPAN class="punctuation token">,</SPAN>
map<SPAN class="punctuation token">:</SPAN> map<SPAN class="punctuation token">,</SPAN>
center<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Point</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>x<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">155000</SPAN><SPAN class="punctuation token">,</SPAN> y<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">463000</SPAN><SPAN class="punctuation token">,</SPAN> spatialReference<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">28992</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN>
zoom<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">3</SPAN>
<SPAN class="keyword token">var</SPAN> layerList <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">LayerList</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
view<SPAN class="punctuation token">:</SPAN> view
view<SPAN class="punctuation token">.</SPAN>ui<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>layerList<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>
position<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"top-right"</SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>head</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>body</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>div</SPAN> <SPAN class="attr-name token">id</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>viewDiv<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>div</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>body</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>html</SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
