There is an updated version for 2.1 release of AppStudio for ArcGIS and AppStudio Player that is available to download now.
This version includes a hotfix that addresses an issue with the Appframework.network.isOnline property, which was always returning true even when not connected to a network on Windows and macOS. With this update, the property will return true if the device is connected to a network, and false when it is not.
Please note that this hotfix only affects AppStudio for ArcGIS and AppStudio Player on the following platforms:
- Windows 32bit
- Windows 64bit
- Mac OS
If you are using AppStudio on Linux, or AppStudio Player on Android, iOS or Linux, you do not need to install this version and you can continue to use the version which was made available in Release 2.1.
With this update, the latest version numbers of AppStudio for ArcGIS and AppStudio Player will be as follows:
| Windows 32bit | Windows 64bit | Mac OS | Android | iOS | Linux |
AppStudio For ArcGIS | 2.1.19 | 2.1.19 | 2.1.19 | 2.1.15 | 2.1.15 | 2.1.15 |
AppStudio Player | 2.1.25 | 2.1.25 | 2.1.25 | 2.1.23 | 2.1.24 | 2.1.23 |
All the downloads are available from: AppStudio for ArcGIS | ArcGIS
