---- Poly* to arrays revisited ----These two scripts help blow poly features into their constituent parts. Initially a null point (np.nan, np.nan) is used to separate the poly features. The location of these insertions is retained and a fr_to index list is maintained so that the resultant 2D points array can be reconstructed or used in other calculations. The outputs are: a_2d, ids, fr_to, id_fr_to which represent the 2D array, the id values of where one poly feature ends, a from-to list is constructed and a final list with the ids prepended is also included. <SPAN class="keyword token">def</SPAN> <SPAN class="token function">_pp_</SPAN><SPAN class="punctuation token">(</SPAN>poly<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="string token">"""See poly_pnts for details. This is for single poly feature conversion
requires
null_pnt = (np.nan, np.nan)
"""</SPAN>
sub <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="comment token"># for i, arr in enumerate(poly):</SPAN>
<SPAN class="keyword token">for</SPAN> arr <SPAN class="keyword token">in</SPAN> poly<SPAN class="punctuation token">:</SPAN>
pnts <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">[</SPAN>pt<SPAN class="punctuation token">.</SPAN>X<SPAN class="punctuation token">,</SPAN> pt<SPAN class="punctuation token">.</SPAN>Y<SPAN class="punctuation token">]</SPAN> <SPAN class="keyword token">if</SPAN> pt <SPAN class="keyword token">else</SPAN> null_pnt <SPAN class="keyword token">for</SPAN> pt <SPAN class="keyword token">in</SPAN> arr<SPAN class="punctuation token">]</SPAN>
sub<SPAN class="punctuation token">.</SPAN>append<SPAN class="punctuation token">(</SPAN>np<SPAN class="punctuation token">.</SPAN>asarray<SPAN class="punctuation token">(</SPAN>pnts<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token">#append(pnts)</SPAN>
<SPAN class="keyword token">return</SPAN> np<SPAN class="punctuation token">.</SPAN>asarray<SPAN class="punctuation token">(</SPAN>sub<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">poly_pnts</SPAN><SPAN class="punctuation token">(</SPAN>in_fc<SPAN class="punctuation token">,</SPAN> as_obj<SPAN class="operator token">=</SPAN><SPAN class="token boolean">False</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="string token">"""Poly features to points while maintaining the location of the points in
the input features. null points are replaced with their numpy equivalent.
Parameters
in_fc : text
Full path to the featureclass.
as_obj : boolean
True returns a list of arrays of the shapes. The array types may be
mixed. False, returns a 2D array of points and an array of indices.
Returns
False, returns a 2D array of points and the location to split
those points should you need to reconstruct the poly feature. A `nan`
point separates the parts of the features within the poly feature, so split
first. If `as_obj` is True, a list of arrays is returned.
Notes
Use `polys = fc_shapes(in_fc)` to obtain the poly features separately.
"""</SPAN>
SR <SPAN class="operator token">=</SPAN> getSR<SPAN class="punctuation token">(</SPAN>in_fc<SPAN class="punctuation token">)</SPAN>
polys <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>SearchCursor<SPAN class="punctuation token">(</SPAN>in_fc<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'SHAPE@'</SPAN><SPAN class="punctuation token">,</SPAN> spatial_reference<SPAN class="operator token">=</SPAN>SR<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> cur<SPAN class="punctuation token">:</SPAN>
polys <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> cur<SPAN class="punctuation token">]</SPAN>
id_too <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN>
a_2d <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="keyword token">for</SPAN> i<SPAN class="punctuation token">,</SPAN> p <SPAN class="keyword token">in</SPAN> enumerate<SPAN class="punctuation token">(</SPAN>polys<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
r <SPAN class="operator token">=</SPAN> _pp_<SPAN class="punctuation token">(</SPAN>p<SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># calls to _pp_ </SPAN>
id_too<SPAN class="punctuation token">.</SPAN>extend<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">(</SPAN>i<SPAN class="punctuation token">,</SPAN> len<SPAN class="punctuation token">(</SPAN>k<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">for</SPAN> k <SPAN class="keyword token">in</SPAN> r<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
a_2d<SPAN class="punctuation token">.</SPAN>extend<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>j <SPAN class="keyword token">for</SPAN> i <SPAN class="keyword token">in</SPAN> r <SPAN class="keyword token">for</SPAN> j <SPAN class="keyword token">in</SPAN> i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
a_2d <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>asarray<SPAN class="punctuation token">(</SPAN>a_2d<SPAN class="punctuation token">)</SPAN>
id_too <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>array<SPAN class="punctuation token">(</SPAN>id_too<SPAN class="punctuation token">)</SPAN>
ids <SPAN class="operator token">=</SPAN> id_too<SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN>
too <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>cumsum<SPAN class="punctuation token">(</SPAN>id_too<SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
frum <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>concatenate<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> too<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
fr_to <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>array<SPAN class="punctuation token">(</SPAN>list<SPAN class="punctuation token">(</SPAN>zip<SPAN class="punctuation token">(</SPAN>frum<SPAN class="punctuation token">,</SPAN> too<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
id_fr_to <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>array<SPAN class="punctuation token">(</SPAN>list<SPAN class="punctuation token">(</SPAN>zip<SPAN class="punctuation token">(</SPAN>ids<SPAN class="punctuation token">,</SPAN> frum<SPAN class="punctuation token">,</SPAN> too<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">if</SPAN> as_obj<SPAN class="punctuation token">:</SPAN>
a_obj <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>a_2d<SPAN class="punctuation token">[</SPAN>f<SPAN class="punctuation token">:</SPAN>t<SPAN class="punctuation token">]</SPAN> <SPAN class="keyword token">for</SPAN> f<SPAN class="punctuation token">,</SPAN>t <SPAN class="keyword token">in</SPAN> fr_to<SPAN class="punctuation token">]</SPAN> <SPAN class="comment token"># alternate constructor</SPAN>
<SPAN class="keyword token">return</SPAN> a_obj<SPAN class="punctuation token">,</SPAN> ids<SPAN class="punctuation token">,</SPAN> fr_to<SPAN class="punctuation token">,</SPAN> id_fr_to
<SPAN class="keyword token">return</SPAN> a_2d<SPAN class="punctuation token">,</SPAN> ids<SPAN class="punctuation token">,</SPAN> fr_to<SPAN class="punctuation token">,</SPAN> id_fr_to
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN> |
A sample run- Line 1 reads the featureclass, produces the 2D point array and the various indices
- In Line 2 and 3, I usually calculate the mean of the point cloud accounting for the null points separating the individual poly features.
- A separate object array can be constructed if you have a need to work with the individual poly features at once, otherwise, you can recreate this using the a array and the fr_to indices as shown in line 4.
- Line 5 reconstructs the original polygons so that they can be moved back into ArcGIS Pro ... more later
Normally you would 'do stuff' between line 4 and 5 and send back the resultant array, but this is just for illustration a<SPAN class="punctuation token">,</SPAN> ids<SPAN class="punctuation token">,</SPAN> fr_to<SPAN class="punctuation token">,</SPAN> id_fr_to <SPAN class="operator token">=</SPAN> poly_pnts<SPAN class="punctuation token">(</SPAN>in_fc<SPAN class="punctuation token">)</SPAN>
m <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>nanmin<SPAN class="punctuation token">(</SPAN>a<SPAN class="punctuation token">,</SPAN> axis<SPAN class="operator token">=</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN>
a_s <SPAN class="operator token">=</SPAN> a <SPAN class="operator token">-</SPAN> m
a1 <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>asarray<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>a<SPAN class="punctuation token">[</SPAN>f<SPAN class="punctuation token">:</SPAN>t<SPAN class="punctuation token">]</SPAN> <SPAN class="keyword token">for</SPAN> f<SPAN class="punctuation token">,</SPAN>t <SPAN class="keyword token">in</SPAN> fr_to<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
p_arr <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>_arr_poly_<SPAN class="punctuation token">(</SPAN>i<SPAN class="punctuation token">,</SPAN> SR<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">for</SPAN> i <SPAN class="keyword token">in</SPAN> a1<SPAN class="punctuation token">]</SPAN> <SPAN class="comment token"># ** to reverse np.concatenate(a1)</SPAN>
frmt <SPAN class="operator token">=</SPAN> <SPAN class="string token">"""
Polygon ids: {}
From-to pairs:
Id_from_to array
"""</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN>dedent<SPAN class="punctuation token">(</SPAN>frmt<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>ids<SPAN class="punctuation token">,</SPAN> fr_to<SPAN class="punctuation token">,</SPAN> id_fr_to<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
Polygon ids<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN> <SPAN class="number token">1</SPAN> <SPAN class="number token">1</SPAN> <SPAN class="number token">2</SPAN> <SPAN class="number token">2</SPAN> <SPAN class="number token">3</SPAN> <SPAN class="number token">4</SPAN><SPAN class="punctuation token">]</SPAN>
From<SPAN class="operator token">-</SPAN>to pairs<SPAN class="punctuation token">:</SPAN>
<SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">[</SPAN> <SPAN class="number token">0</SPAN> <SPAN class="number token">5</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="punctuation token">[</SPAN> <SPAN class="number token">5</SPAN> <SPAN class="number token">16</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="punctuation token">[</SPAN><SPAN class="number token">16</SPAN> <SPAN class="number token">26</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="punctuation token">[</SPAN><SPAN class="number token">26</SPAN> <SPAN class="number token">36</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="punctuation token">[</SPAN><SPAN class="number token">36</SPAN> <SPAN class="number token">48</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="punctuation token">[</SPAN><SPAN class="number token">48</SPAN> <SPAN class="number token">57</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="punctuation token">[</SPAN><SPAN class="number token">57</SPAN> <SPAN class="number token">65</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">]</SPAN>
Id_from_to array
<SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">[</SPAN> <SPAN class="number token">0</SPAN> <SPAN class="number token">0</SPAN> <SPAN class="number token">5</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="punctuation token">[</SPAN> <SPAN class="number token">1</SPAN> <SPAN class="number token">5</SPAN> <SPAN class="number token">16</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="punctuation token">[</SPAN> <SPAN class="number token">1</SPAN> <SPAN class="number token">16</SPAN> <SPAN class="number token">26</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="punctuation token">[</SPAN> <SPAN class="number token">2</SPAN> <SPAN class="number token">26</SPAN> <SPAN class="number token">36</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="punctuation token">[</SPAN> <SPAN class="number token">2</SPAN> <SPAN class="number token">36</SPAN> <SPAN class="number token">48</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="punctuation token">[</SPAN> <SPAN class="number token">3</SPAN> <SPAN class="number token">48</SPAN> <SPAN class="number token">57</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="punctuation token">[</SPAN> <SPAN class="number token">4</SPAN> <SPAN class="number token">57</SPAN> <SPAN class="number token">65</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Line 15 shows that poly features 1 and 2 have 2 parts. Lines 16-23 are the from-to pairs of points needed to reconstruct the arrays to make polygons. Line 24- just combines the two previous lists. |
Reconstructing the arrays to poly featuresThe code below does this. A helper function, then the code block that uses a search cursor to reassemble the array to something that arcpy can use. Sadly you have to go from a numpy array, then create points, which are placed in an arcpy Array and from there the arcpy.Arrays are assembled to form polygon or polyline features. And Finally!!! A single-part featureclass is created, then a multipart featureclass, like the original data that went into the whole process. Complicated? Not really, the real bottleneck is the cursors. You need them going in (regardless of the shroud placed around them) and going out. (ie __geo_interface__, _as_narray, FeatureClassToNumPyArray. I should point out here that Numpyarraytofeatureclass works with simple geometry to get poly features back, but who works with simple features all the time. <SPAN class="keyword token">def</SPAN> <SPAN class="token function">_arr_poly_</SPAN><SPAN class="punctuation token">(</SPAN>pnts<SPAN class="punctuation token">,</SPAN> SR<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="string token">"""Single array to polygon, array can be multipart with or without interior
rings. Outer rings are ordered clockwise, inner rings (holes) are ordered
counterclockwise. For polylines, there is no concept of order
Splitting is modelled after _nan_split_(arr)
"""</SPAN>
subs <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN>
s <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>isnan<SPAN class="punctuation token">(</SPAN>pnts<SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">if</SPAN> np<SPAN class="punctuation token">.</SPAN>any<SPAN class="punctuation token">(</SPAN>s<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
w <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>where<SPAN class="punctuation token">(</SPAN>s<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN>
ss <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>split<SPAN class="punctuation token">(</SPAN>pnts<SPAN class="punctuation token">,</SPAN> w<SPAN class="punctuation token">)</SPAN>
subs <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>ss<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">]</SPAN>
subs<SPAN class="punctuation token">.</SPAN>extend<SPAN class="punctuation token">(</SPAN>i<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="keyword token">for</SPAN> i <SPAN class="keyword token">in</SPAN> ss<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">else</SPAN><SPAN class="punctuation token">:</SPAN>
subs<SPAN class="punctuation token">.</SPAN>append<SPAN class="punctuation token">(</SPAN>pnts<SPAN class="punctuation token">)</SPAN>
aa <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="keyword token">for</SPAN> sub <SPAN class="keyword token">in</SPAN> subs<SPAN class="punctuation token">:</SPAN>
aa<SPAN class="punctuation token">.</SPAN>append<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>arcpy<SPAN class="punctuation token">.</SPAN>Point<SPAN class="punctuation token">(</SPAN><SPAN class="operator token">*</SPAN>pairs<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">for</SPAN> pairs <SPAN class="keyword token">in</SPAN> sub<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
poly <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Polygon<SPAN class="punctuation token">(</SPAN>arcpy<SPAN class="punctuation token">.</SPAN>Array<SPAN class="punctuation token">(</SPAN>aa<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> SR<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">return</SPAN> poly
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">arr_poly_fc</SPAN><SPAN class="punctuation token">(</SPAN>a<SPAN class="punctuation token">,</SPAN> p_type<SPAN class="operator token">=</SPAN><SPAN class="string token">'POLYGON'</SPAN><SPAN class="punctuation token">,</SPAN> gdb<SPAN class="operator token">=</SPAN>None<SPAN class="punctuation token">,</SPAN> fname<SPAN class="operator token">=</SPAN>None<SPAN class="punctuation token">,</SPAN> sr<SPAN class="operator token">=</SPAN>None<SPAN class="punctuation token">,</SPAN> ids<SPAN class="operator token">=</SPAN>None<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="string token">"""Reform poly features from the list of arrays created by poly_pnts
Parameters
a : array or list of arrays
Some can be object arrays, normally created by ``pnts_arr``
p_type : string
Uppercase geometry type
gdb : text
Geodatabase name
fname : text
Featureclass name
sr : spatial reference
name or object
ids : list/array
Identifies which feature each input belongs to. This enables one to
account for multipart shapes.
``_arr_poly_`` is required
"""</SPAN>
<SPAN class="keyword token">if</SPAN> ids <SPAN class="keyword token">is</SPAN> None<SPAN class="punctuation token">:</SPAN>
ids <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>arange<SPAN class="punctuation token">(</SPAN>len<SPAN class="punctuation token">(</SPAN>a<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>tolist<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">for</SPAN> i <SPAN class="keyword token">in</SPAN> a<SPAN class="punctuation token">:</SPAN>
p <SPAN class="operator token">=</SPAN> _arr_poly_<SPAN class="punctuation token">(</SPAN>i<SPAN class="punctuation token">,</SPAN> sr<SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># ---- use _arr_poly</SPAN>
polys<SPAN class="punctuation token">.</SPAN>append<SPAN class="punctuation token">(</SPAN>p<SPAN class="punctuation token">)</SPAN>
out <SPAN class="operator token">=</SPAN> list<SPAN class="punctuation token">(</SPAN>zip<SPAN class="punctuation token">(</SPAN>polys<SPAN class="punctuation token">,</SPAN> ids<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
name <SPAN class="operator token">=</SPAN> gdb <SPAN class="operator token">+</SPAN> <SPAN class="string token">"\\"</SPAN> <SPAN class="operator token">+</SPAN> fname
wkspace <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>env<SPAN class="punctuation token">.</SPAN>workspace <SPAN class="operator token">=</SPAN> <SPAN class="string token">'in_memory'</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>management<SPAN class="punctuation token">.</SPAN>CreateFeatureclass<SPAN class="punctuation token">(</SPAN>wkspace<SPAN class="punctuation token">,</SPAN> fname<SPAN class="punctuation token">,</SPAN> p_type<SPAN class="punctuation token">,</SPAN>
spatial_reference<SPAN class="operator token">=</SPAN>sr<SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>management<SPAN class="punctuation token">.</SPAN>AddField<SPAN class="punctuation token">(</SPAN>fname<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'ID_arr'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'LONG'</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>InsertCursor<SPAN class="punctuation token">(</SPAN>fname<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'SHAPE@'</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">'ID_arr'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> cur<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> out<SPAN class="punctuation token">:</SPAN>
cur<SPAN class="punctuation token">.</SPAN>insertRow<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">)</SPAN>
out_fname <SPAN class="operator token">=</SPAN> fname <SPAN class="operator token">+</SPAN> <SPAN class="string token">"_mp"</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>management<SPAN class="punctuation token">.</SPAN>Dissolve<SPAN class="punctuation token">(</SPAN>fname<SPAN class="punctuation token">,</SPAN> out_fname<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"ID_arr"</SPAN><SPAN class="punctuation token">,</SPAN>
multi_part<SPAN class="operator token">=</SPAN><SPAN class="string token">"MULTI_PART"</SPAN><SPAN class="punctuation token">,</SPAN>
unsplit_lines<SPAN class="operator token">=</SPAN><SPAN class="string token">"DISSOLVE_LINES"</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>management<SPAN class="punctuation token">.</SPAN>CopyFeatures<SPAN class="punctuation token">(</SPAN>out_fname<SPAN class="punctuation token">,</SPAN> name<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">del</SPAN> cur
<SPAN class="keyword token">return</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN> |
Some ResultsSo just to compare the geometries, I will compare the areas calculated using arcpy and those calculated using the function below. polys <SPAN class="operator token">=</SPAN> fc_shapes<SPAN class="punctuation token">(</SPAN>in_fc<SPAN class="punctuation token">)</SPAN>
areas <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>p<SPAN class="punctuation token">.</SPAN>area <SPAN class="keyword token">for</SPAN> p <SPAN class="keyword token">in</SPAN> polys<SPAN class="punctuation token">]</SPAN>
areas1 <SPAN class="operator token">=</SPAN> poly_area<SPAN class="punctuation token">(</SPAN>a<SPAN class="punctuation token">,</SPAN> ids<SPAN class="punctuation token">,</SPAN> fr_to<SPAN class="punctuation token">)</SPAN>
areas <SPAN class="comment token"># [100.0, 78.0, 155.0, 52.0, 36.0]</SPAN>
areas1 <SPAN class="comment token"># array([100., 78., 155., 52., 36.])</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN> Looks good. The helper function employs my favorite numpy function einsum, to implement the shoelace formula. A tad overkill for these teeny polygons, but it works blazingly fast for huge point arrays representing real world polygons. <SPAN class="keyword token">def</SPAN> <SPAN class="token function">poly_area</SPAN><SPAN class="punctuation token">(</SPAN>a<SPAN class="punctuation token">,</SPAN> ids<SPAN class="punctuation token">,</SPAN> fr_to<SPAN class="operator token">=</SPAN>None<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="string token">"""Calculate of a 2D array sliced into sections using an indices of the
bounds. ``a`` is created from ``poly_pnts``
"""</SPAN>
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">_e_area</SPAN><SPAN class="punctuation token">(</SPAN>a<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="string token">"""mini e_area with a twist, shoelace formula using einsum"""</SPAN>
x0<SPAN class="punctuation token">,</SPAN> y1 <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN>a<SPAN class="punctuation token">.</SPAN>T<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">]</SPAN>
x1<SPAN class="punctuation token">,</SPAN> y0 <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN>a<SPAN class="punctuation token">.</SPAN>T<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">:</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN>
e0 <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>einsum<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'...i,...i->...i'</SPAN><SPAN class="punctuation token">,</SPAN> x0<SPAN class="punctuation token">,</SPAN> y0<SPAN class="punctuation token">)</SPAN>
e1 <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>einsum<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'...i,...i->...i'</SPAN><SPAN class="punctuation token">,</SPAN> x1<SPAN class="punctuation token">,</SPAN> y1<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">return</SPAN> np<SPAN class="punctuation token">.</SPAN>nansum<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN>e0<SPAN class="operator token">-</SPAN>e1<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">*</SPAN><SPAN class="number token">0.5</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># ---- </SPAN>
subs <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>_e_area<SPAN class="punctuation token">(</SPAN>a<SPAN class="punctuation token">[</SPAN>f<SPAN class="punctuation token">:</SPAN>t<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">for</SPAN> f<SPAN class="punctuation token">,</SPAN>t <SPAN class="keyword token">in</SPAN> fr_to<SPAN class="punctuation token">]</SPAN>
totals <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>bincount<SPAN class="punctuation token">(</SPAN>ids<SPAN class="punctuation token">,</SPAN> weights<SPAN class="operator token">=</SPAN>subs<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">return</SPAN> totals<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>I could calculate the area and length properties as I construct the arrays, like cursors do so that the property is readily available. I find if I wanted those properties I would calculate them, and I don't need them floating around unused. poly_area is only one of my helper functions for calculating poly properties. These will be assembled at some stage and posted on GitHub and the Code Sharing site. |
