I'm trying to publish a 3d Scene from ArcGis pro. When I attempt to add my portal it fails.
I installed ArcGis Server 10.4 and added a data source.
I installed WebAdaptor.
I installed ArcGis Portal 10.4 and configured WebAdaptor
https://xyz.xyz.xyz.xyz/arcgis/home/ works.
https://xyz.xyz.xyz.xyz/:7443/arcgis/home/ works
from ArcGis Pro I add the portal
it says: "Unable to add the portal. Please make sure that the specified portal is up, running and the URL is correct."
as does /home
If I add the :7443 it works kinda - it registers but if I log in it simply does nothing.
--- If I give it the wrong creds - it says they are the wrong creds.
--- If I give it the correct creds - the pop-up login window closes and the portal entry in the list box says I need to log in.
Thanks in advance.
