Today I stumbled upon a tweet showing how children in Japan are using line intersections to calculate the multiplication of two numbers. I was amazed by the beauty of the method which can be extended to larger numbers too. Just take a look at the example below:
Source: http://www.pinpopular.com/japanese-multiplication-trick-pinterest-education/
It is basically counting intersections of lines. Wait ... intersections of lines ... sounds to me that arcpy could do that too. So, why not write some arcpy / python code to multiply 2 numbers?
I know, what you're thinking ... why? Because it's fun and completely useless!
So this is what I came up with:
# Japanese visual multiplication with arcpy
import arcpy
import os
ws = r"C:\Forum\JapaneseMultiply\fgdb\test.gdb"
arcpy.env.workspace = ws
sr = arcpy.SpatialReference(3857)
arcpy.env.outputCoordinateSystem = sr
# values to multiply:
value1 = 47 # (1 -99)
value2 = 63 # (1 -99)
fc_points = "points"
fc_lines_h = "lines_h"
fc_lines_v = "lines_v"
fc_polygones = "polygons"
fc_result = "result"
size = 10
fld_factor = "factor"
val_h1 = value1 / 10
val_h2 = value1 % 10
val_v1 = value2 / 10
val_v2 = value2 % 10
# create horizontal lines
arcpy.CreateFeatureclass_management(ws, fc_lines_h, "POLYLINE", "#", "DISABLED", "DISABLED", sr)
with arcpy.da.InsertCursor(fc_lines_h, ("SHAPE@")) as rows:
for y in range(1, val_h1 + 1):
x1 = -1 * size
x2 = size
array = arcpy.Array([arcpy.Point(x1, y),
arcpy.Point(x2, y)])
polyline = arcpy.Polyline(array)
rows.insertRow([polyline])
for y in range(1, val_h2 + 1):
x1 = -1 * size
x2 = size
array = arcpy.Array([arcpy.Point(x1, -1 * y),
arcpy.Point(x2, -1 * y)])
# create vertical lines
arcpy.CreateFeatureclass_management(ws, fc_lines_v, "POLYLINE", "#", "DISABLED", "DISABLED", sr)
with arcpy.da.InsertCursor(fc_lines_v, ("SHAPE@")) as rows:
for x in range(1, val_v1 + 1):
y1 = -1 * size
y2 = size
array = arcpy.Array([arcpy.Point(-1 * x, y1),
arcpy.Point(-1 * x, y2)])
for x in range(1, val_v2 + 1):
y1 = -1 * size
y2 = size
array = arcpy.Array([arcpy.Point(x, y1),
arcpy.Point(x, y2)])
# Create polygon cuadrants
arcpy.CreateFeatureclass_management(ws, fc_polygones, "POLYGON", "#", "DISABLED", "DISABLED", sr)
arcpy.AddField_management(fc_polygones, fld_factor, "DOUBLE")
with arcpy.da.InsertCursor(fc_polygones, ("SHAPE@", fld_factor)) as rows:
# left top factor 100
factor = 100
array = arcpy.Array([arcpy.Point(-1 * size, 0),
arcpy.Point(-1 * size, size),
arcpy.Point(0, size),
arcpy.Point(0, 0),
arcpy.Point(-1 * size, 0)])
polygon = arcpy.Polygon(array)
rows.insertRow([polygon, factor])
# right top factor 10
factor = 10
array = arcpy.Array([arcpy.Point(0, 0),
arcpy.Point(size, size),
arcpy.Point(size, 0),
arcpy.Point(0, 0)])
# left bottom factor 10
factor = 10
array = arcpy.Array([arcpy.Point(-1 * size, -1 * size),
arcpy.Point(0, 0),
arcpy.Point(0, -1 * size),
arcpy.Point(-1 * size, -1 * size)])
# right bottom factor 1
factor = 1
arcpy.Point(size, -1 * size),
arcpy.Point(0, 0)])
# start analysis: intersect horizontal and vertical lines
arcpy.Intersect_analysis([fc_lines_h, fc_lines_v], fc_points, "ALL", "", "POINT")
# Next intersect the polygon with the points (intersection of lines)
arcpy.Intersect_analysis([fc_polygones, fc_points], fc_result)
# now use Search cursor to get result
res = 0
with arcpy.da.SearchCursor(fc_result, (fld_factor)) as rows:
for row in rows:
factor = row[0]
res += factor
print "{0} * {1} = {2}".format(value1, value2, res)
print "verify: {0} * {1} = {2}".format(value1, value2, value1 * value2)
In the example above the following result is printed:
47 * 63 = 2961.0
verify: 47 * 63 = 2961
Displaying the featureclasses gives the following result:
I hope my next blog post will be of more use.
Xander
