Reorder numbered points in an express map
Say you have an express map with five numbered points representing places you visited on your latest vacation.
You added the points for each place in the order in which you visited them, but now you’ve changed your mind and want the numbers to serve as a ranking for enjoyment at each destination. Don’t panic, there’s no need to delete your points and start over. In the Map layers tab of the map designer’s side panel you’ll see your points listed with point one at the top and point five at the bottom. To reorder your list, click and drag the point name for each place, dropping them into your preferred sequence. The numbers for each point on your map will update as you make changes in the side panel, and all that pop-up information you already added for each point is preserved just as you had it.
