I have been customizing an application from a template of 3.2 Map Viewer in AppStudio 3.2.
Recently, after an upgrade to AppStudio 3.3, my application crashes as soon as my map loads (and before the features points can be loaded) on the AppStudio Run -- without any messages in the QtCreator General Message pane. I suspect it is an AppStudio version problem, as I return to AppStudio version 3.2, the features can be loaded without problem (on AppStudio Run).
Therefore, I have attempted:
1) cloud make for Android: same problem appears.
2) cloud build on a MacBookPro (for iOS version): same problem.
Please advice if anyone has workarounds or potential solutions to this. Would it be some outdated packages that I have implemented?
Updated So I have discovered in my code that I added the line in red and lead to the error, it was NOT in the original MapViewer template. (I believe it was in the 100.2 API though? It is in the 100.5 API, but I am unable to find the older API references)
Map { initUrl: mapPage.portalItem.type === "Web Map" ? mapPage.portalItem.url : ""
// Line below leads to error
autoFetchLegendInfos: true
My question now, is how may I trace trace these errors -- are there procedures that I have omitted? I believe that there must be some methods to traceback to the error. The app did not crash on the devices, but only closed itself. I did not know how I could find the error output -- on Android, iOS and desktop, but to compare the template to my own code.
Ronnie
Sample crash message from Android logcat (cloud build)
--------- beginning of crash
2019-04-23 16:39:54.112 1369-1386/? A/libc: Fatal signal 11 (SIGSEGV), code 1, fault addr 0x4900 in tid 1386 (qtMainLoopThrea)
2019-04-23 16:39:54.238 3276-3276/? E/audit: type=1400 audit(1556008794.232:955): avc: denied { search } for pid=1454 comm="crash_dump32" name="com.esri.xxxxxxxxxxxxxxxxxxx" dev="dm-1" ino=329648 scontext=u:r:crash_dump:s0:c512,c768 tcontext=u:object_r:app_data_file:s0:c512,c768 tclass=dir permissive=0 SEPF_SM-G930F_8.0.0_0018 audit_filtered
2019-04-23 16:39:54.244 3276-3276/? E/audit: type=1400 audit(1556008794.232:988): avc: denied { search } for pid=1454 comm="crash_dump32" name="com.esri.xxxxxxxxxxxxxxxxxxx" dev="dm-1" ino=329648 scontext=u:r:crash_dump:s0:c512,c768 tcontext=u:object_r:app_data_file:s0:c512,c768 tclass=dir permissive=0 SEPF_SM-G930F_8.0.0_0018 audit_filtered
2019-04-23 16:39:54.278 1454-1454/? A/DEBUG: *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
2019-04-23 16:39:54.279 1454-1454/? A/DEBUG: Build fingerprint: 'samsung/heroltexx/herolte:8.0.0/R16NW/G930FXXS4ESC7:user/release-keys'
2019-04-23 16:39:54.279 1454-1454/? A/DEBUG: Revision: '8'
2019-04-23 16:39:54.279 1454-1454/? A/DEBUG: ABI: 'arm'
2019-04-23 16:39:54.279 1454-1454/? A/DEBUG: pid: 1369, tid: 1386, name: qtMainLoopThrea >>> com.esri.xxxxxxxxxxxxxxxxxxx <<<
2019-04-23 16:39:54.279 1454-1454/? A/DEBUG: signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 0x4900
2019-04-23 16:39:54.279 1454-1454/? A/DEBUG: r0 a763add8 r1 00004900 r2 00000000 r3 c8cf44b8
2019-04-23 16:39:54.279 1454-1454/? A/DEBUG: r4 0000000c r5 dbdea8e8 r6 9008001c r7 c8c7e680
2019-04-23 16:39:54.279 1454-1454/? A/DEBUG: r8 90080010 r9 9d93b678 sl 0000000b fp a7850dd0
2019-04-23 16:39:54.279 1454-1454/? A/DEBUG: ip ea473d58 sp c8c7e668 lr ea44aec1 pc c4198ec0 cpsr a00f0030
2019-04-23 16:39:54.283 1454-1454/? A/DEBUG: backtrace:
2019-04-23 16:39:54.283 1454-1454/? A/DEBUG: #00 pc 0052bec0 /data/app/com.esri.xxxxxxxxxxxxxxxxxxx-BpTejyBNnNe0RFnYDq7bKw==/lib/arm/libEsriCommonQt.so (offset 0x51a000)
2019-04-23 16:39:54.283 1454-1454/? A/DEBUG: #01 pc 0051f7a5 /data/app/com.esri.xxxxxxxxxxxxxxxxxxx-BpTejyBNnNe0RFnYDq7bKw==/lib/arm/libEsriCommonQt.so (offset 0x51a000)
2019-04-23 16:39:54.283 1454-1454/? A/DEBUG: #02 pc 00582b17 /data/app/com.esri.xxxxxxxxxxxxxxxxxxx-BpTejyBNnNe0RFnYDq7bKw==/lib/arm/libEsriCommonQt.so (offset 0x51a000)
2019-04-23 16:39:54.283 1454-1454/? A/DEBUG: #03 pc 00582f51 /data/app/com.esri.xxxxxxxxxxxxxxxxxxx-BpTejyBNnNe0RFnYDq7bKw==/lib/arm/libEsriCommonQt.so (offset 0x51a000)
2019-04-23 16:39:54.283 1454-1454/? A/DEBUG: #04 pc 0015b0e7 /data/app/com.esri.xxxxxxxxxxxxxxxxxxx-BpTejyBNnNe0RFnYDq7bKw==/lib/arm/libQt5Core.so (_ZN14QMetaCallEvent13placeMetaCallEP7QObject+30)
2019-04-23 16:39:54.283 1454-1454/? A/DEBUG: #05 pc 0015baf3 /data/app/com.esri.xxxxxxxxxxxxxxxxxxx-BpTejyBNnNe0RFnYDq7bKw==/lib/arm/libQt5Core.so (_ZN7QObject5eventEP6QEvent+250)
2019-04-23 16:39:54.283 1454-1454/? A/DEBUG: #06 pc 00107357 /data/app/com.esri.xxxxxxxxxxxxxxxxxxx-BpTejyBNnNe0RFnYDq7bKw==/lib/arm/libQt5Widgets.so (_ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent+152)
2019-04-23 16:39:55.160 3335-3335/? E//system/bin/tombstoned: Tombstone written to: /data/tombstones//tombstone_09
2019-04-23 16:39:55.289 3664-3692/? E/PhoneWindow_APM :: isCalledPackage return false
2019-04-23 16:39:55.300 3187-3187/? E/Sensors: inject_scontext_data: New ssp_data_injection_fd(27)
2019-04-23 16:39:55.371 3197-3197/? E/SurfaceFlinger: removeLayer called with a layer whose parent has been removed
