Hi, I have a problem with the Editor-Interface after running a Model in ModelBuilder (ArcMap 10.4.1).
In the "Edit"-mode of ModelBuilder Parameter and Data have blue/ green boxes and the Tools have yellow boxes. This display doesn´t change after running Model via "Run" or "Run Entire Model" in the Editor-Interface. But if I run the Model with right click and "Open" or double-click the Model the diagram is changed after. There are no yellow boxes around the Tools in the "Edit"-mode and I can´t open the Tools with double-click.
What is the problem or is this normal?
Sorry for bad language
