Hello All,
I am trying to get a custom widget(CW) to work that uses a map click event. The widget works as standalone but if also using the OOTB measurement widget(MW) I get weird behavior. If I use the OOTB MW before I use the CW then I get expected behavior for both tools. However, if I use the CW followed by the MW, when I close the CW the symbol it uses is cleared from the map but when using the MW the symbol replaces esri greenpin, the line segments disappear on dbl-clicks, and when MW is closed, the CW symbol remains.
