When I Create Enterprise Geodatabase using toolbox in ArcCatalog it errors below. also I create database in SQL server then I add geodatabase connection to arccatalog but when I enable enterprise geodatabase it same errors
I use ArcGIS Desktop 10.3.1 and SQL Server 2014.
What is the error?
[Operastion Failed]
See the setup log in the following location for additional error information:
Colud not create geodatabase tables and stored procedures
Failed to execute (EnableEnterpriseGeodatabase)
LOG INFO:
[Thu Jul 14 15:11:09 2016] VERSION table created...
[Thu Jul 14 15:11:09 2016] SPATIAL_REFERENCES table being created...
[Thu Jul 14 15:11:09 2016] SPATIAL_REFERENCES table created...
[Thu Jul 14 15:11:09 2016] GEOMETRY_COLUMNS table being created...
[Thu Jul 14 15:11:09 2016] GEOMETRY_COLUMNS table created...
[Thu Jul 14 15:11:09 2016] LAYERS table being created...
[Thu Jul 14 15:11:09 2016] LAYERS table created...
[Thu Jul 14 15:11:09 2016] METADATA table being created...
[Thu Jul 14 15:11:09 2016] METADATA table created...
[Thu Jul 14 15:11:09 2016] RASTER_COLUMNS table being created...
[Thu Jul 14 15:11:09 2016] RASTER_COLUMNS table created...
[Thu Jul 14 15:11:09 2016] TABLE_REGISTRY table being created...
[Thu Jul 14 15:11:09 2016] TABLE_REGISTRY table created...
[Thu Jul 14 15:11:09 2016] STATES table being created...
[Thu Jul 14 15:11:09 2016] STATES table created...
[Thu Jul 14 15:11:09 2016] VERSIONS table being created...
[Thu Jul 14 15:11:09 2016] VERSIONS table created...
[Thu Jul 14 15:11:09 2016] MVTABLES_MODIFIED table being created...
[Thu Jul 14 15:11:09 2016] MVTABLES_MODIFIED table created...
[Thu Jul 14 15:11:09 2016] STATE_LINEAGES table being created...
[Thu Jul 14 15:11:09 2016] ERROR in creating STATE_LINEAGES table.
Error: -38
[Thu Jul 14 15:11:09 2016] DBMS error code: 0
[Thu Jul 14 15:11:09 2016] SDE schema object install not completed.
[Thu Jul 14 15:11:09 2016] ERROR installing/upgrading ArcSDE, Error = -1
