How does Business Analyst report calculate, for example, 'total households' in a 20-min drive time polygon when the household data is aggregated at the block level and the 20-min drive time polygon cuts thru the actual block polygons on the outside edges? I'm assuming Business Analyst returns a household count for those block records only partially included in the drive time polygon based on the geographic area of that block that is contained inside the drive time polygon. If half of the block is inside the drive time polygon, then half of the total households are included in the drive time total for that block record. Is this correct?
