In model builder I am attempting to Clip a Feature which has Selected Attributes by each polygon in another feature. This model will get the desired output. But, it will "Select Layer By Attribute" each time. Making the process slower.
I've tried variations of putting either the 'top' or 'bottom' commands before clip into submodels, but this has resulted in the same behavior. I've tried different iterators (e.g., use split by attributes on the clipping feature and then a feature class iterator) to no avail. If export to python code I can see that 'arcpy.SelectLayerByAttribute_management" is in the same for loop as 'clip'. How might I adjust this model to no longer "Select Layer By Attribute" for each clipping polygon?
