Hi all,
I'm trying to customize the behavior of the default/standard edit widget:
Currently when you add a feature,
1) you need to select the template
2) then click on map
3) then you need to close the popup that is opened and go to point 1
My client need to insert hundreds of points so I'm trying to simplify the process:
1) select the template
2) Click on map, feature is added BUT is not selected nor template selection is NOT cleared
3) User can continuously click on map to add more features/points
Is this even possible? should I create a new widget?
I'd really appreciate any hints
