I have used Robert's Enhanced Search widget to create a custom widget that sends data to the Print widget if a feature is selected.
There are cases where the user would like to use the graphical search tab to draw a box around a point, which is fine. The graphic works fine by itself if you use it back to back, but the problem occurs after you use the Print function. After you Print, you cannot go back into the graphical search bar and re-select a shape, which means the user has to refresh the page and then re-select another point, print, refresh page, select, print, etc. (very cumbersome!). Is there a part of the code that I am missing that is not releasing
