Hi All,
I have a shapefiles that contains multiple polygons.
For each polygon, there is a order number under "Sequence" field. Nothing too complicated, just 1,2,3,..... etc
Is there a way to clip those layers based on order number using modelbuilder?
For instance, Polygon 1 clip out polygon 2, polygon 2 clip out polygon 3, polygon 3 clip out polygon 4, if polygon 5 stays by itself and do not overlap anything, then it will be by itseft.
Thanks in advance.
