I have an AppStudio app that generates+syncs a runtime geodatabase from a feature service and then displays some layers on a map. How can I give my users the ability to remove that .geodatabase file while the app is running?
In my app I have a button that when clicked:
1) removes all FeatureLayers from the map
2) changes all GeodatabaseFeatureTables to not point to my .geodatabase file anymore
Then it executes FileFolder.removeFile("gdb.geodatabase"), but it fails to delete the file!
In my code I do declare a QML Geodatabase component that uses the "gdb.geodatabase" file, and when I comment that section out the file does indeed get deleted successfully. Can I modify my Geodatabase component to not prevent the deletion of my .geodatabase file while the app is running? I tried changing the Geodatabase "path" property but that doesn't seem to release the lock.
Thanks for you advice.
