To support my custom workflow I have made small change jimu.js/LayoutManager.js. The change that I have made is creating an object that I then publish within this file as follows
topic.publish("channel_id","object with attributes i need to pass to widget");
I have a custom widget in my application that I would like to subscribe to the channel specified above when the user launches the widget to use it.
i have tried this in the startup method of my custom widget
topic.subscribe("channel_id",function (e){
alert(JSON.stringify(e));
My custom widget does seem to be able to subscribe to the channel published from LayoutManager.js. Is this possible? Is there any other way I can achieve this? Any pointers will be gratefully received.
